Helmet Visor Cleaning. - Page 2 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 05-23-2007, 07:40 PM   #11 (permalink)
adrenaline1x's Avatar
adrenaline1x has at least 2000 rep pointsadrenaline1x has at least 2000 rep pointsadrenaline1x has at least 2000 rep pointsadrenaline1x has at least 2000 rep pointsadrenaline1x has at least 2000 rep pointsadrenaline1x has at least 2000 rep pointsadrenaline1x has at least 2000 rep pointsadrenaline1x has at least 2000 rep pointsadrenaline1x has at least 2000 rep pointsadrenaline1x has at least 2000 rep pointsadrenaline1x has at least 2000 rep points
[:++1] on the on windex, bad stuff, you can go to any car parts store and pick up some tint-safe window cleaner which will do the trick as well
adrenaline1x is offline   Reply With Quote
Old 05-23-2007, 07:54 PM   #12 (permalink)
suckafree's Avatar
suckafree has at least 50 rep points
warm water always works for me.
suckafree is offline   Reply With Quote
Old 05-23-2007, 10:53 PM   #13 (permalink)
hextavo's Avatar
hextavo has at least 500 rep pointshextavo has at least 500 rep pointshextavo has at least 500 rep pointshextavo has at least 500 rep pointshextavo has at least 500 rep pointshextavo has at least 500 rep points
Originally Posted by kevalent
I just use warm water with a couple drops of liquid soap (hand or dish, whatever is within reach). Lather it up and rinse with warm-hot water and wipe dry with a soft towel. Not a single scratch or water-spot from cleaning in 5 years .
For quick clean-ups if it's not too dirty I use a soft rag and a spritz of Stoner Glass Cleaner.
Warm water w/liquid soap all the way!! I don't put soap on the inside though, I figure enough soapy water will run in there to have enough of a effect! I also try not to rub on the inside cause I like my visor fog-free! Also when I'm at gas stations after a long ride I go to the window cleaning stations, dip one of the towels in the glass cleaner and was my closed visor that way!! does wonders to get a massive hoard of bugs off!
hextavo is offline   Reply With Quote
Old 05-24-2007, 01:02 AM   #14 (permalink)
Kawi Supporter
spoonman's Avatar
spoonman is around zero rep points
Def. warm water or Plexus. Windex destroys 'em!
spoonman is offline   Reply With Quote
Old 05-24-2007, 03:15 AM   #15 (permalink)
Zymosis's Avatar
Zymosis is around zero rep points
Warm water and dish soap or 3M Plastic Cleaner or Plexus.
Zymosis is offline   Reply With Quote
Old 05-24-2007, 06:03 AM   #16 (permalink)
asteelo's Avatar
asteelo has between 60,000 and 70,000 rep pointsasteelo has between 60,000 and 70,000 rep pointsasteelo has between 60,000 and 70,000 rep pointsasteelo has between 60,000 and 70,000 rep pointsasteelo has between 60,000 and 70,000 rep pointsasteelo has between 60,000 and 70,000 rep pointsasteelo has between 60,000 and 70,000 rep pointsasteelo has between 60,000 and 70,000 rep pointsasteelo has between 60,000 and 70,000 rep pointsasteelo has between 60,000 and 70,000 rep pointsasteelo has between 60,000 and 70,000 rep points
Send a message via Skype™ to asteelo
plexus is the shizzle. Plexus and a microfiber cloth will keep the shield clean, streak free, and fog resistant for years and years.
When you get a scratch though, if you know what you're doing, Novus makes some acrylic products that can buff them out. Only good for the outside though, dont ever get the stuff on the inside and forget it on mirrored shields. If you dont quite have the technique down, then buying a new shield isnt a bad idea.
asteelo is offline   Reply With Quote
Old 12-04-2012, 11:28 AM   #17 (permalink)
Sobe34 Sobe34
Talking
I use this Nikwax Visor Proof (Not Anti-Fog) - The Helmet Harbor, LLC. Works great! Hope this helps..
Sobe34 is offline   Reply With Quote
Old 12-04-2012, 12:39 PM   #18 (permalink)
Strider007's Avatar
Strider007 has at least 500 rep pointsStrider007 has at least 500 rep pointsStrider007 has at least 500 rep pointsStrider007 has at least 500 rep pointsStrider007 has at least 500 rep pointsStrider007 has at least 500 rep pointsStrider007 has at least 500 rep points
I use warm water and dish soap as well, then pat dry with a paper towel (don't rub with the paper towel).
2009 ZX-6R (32,000 miles and counting)
Strider007 is offline   Reply With Quote
Old 12-04-2012, 01:25 PM   #19 (permalink)
Steve Mcqueen Wannabe!
bRiT636's Avatar
bRiT636 has at least 80,000 rep pointsbRiT636 has at least 80,000 rep pointsbRiT636 has at least 80,000 rep pointsbRiT636 has at least 80,000 rep pointsbRiT636 has at least 80,000 rep pointsbRiT636 has at least 80,000 rep pointsbRiT636 has at least 80,000 rep pointsbRiT636 has at least 80,000 rep pointsbRiT636 has at least 80,000 rep pointsbRiT636 has at least 80,000 rep pointsbRiT636 has at least 80,000 rep points
holy thread from the dead. I would have voted plexus, but have you seen the cost increase in the last few years...
05 636 * K&N Air * SS Goodridge frt T-lines * Arata Rearsets * PCIII * Akro Slipon-micron headers* GPR V1 Damper * Michelin Pilot Ones* Elka Triple shock *Nissin calipers* Ohlins 20 mm forks* Keyless entry* what Bikes are about
bRiT636 is offline   Reply With Quote
Old 12-04-2012, 01:53 PM   #20 (permalink)
ninja500hs's Avatar
ninja500hs has between 5,000 and 7,500 rep pointsninja500hs has between 5,000 and 7,500 rep pointsninja500hs has between 5,000 and 7,500 rep pointsninja500hs has between 5,000 and 7,500 rep pointsninja500hs has between 5,000 and 7,500 rep pointsninja500hs has between 5,000 and 7,500 rep pointsninja500hs has between 5,000 and 7,500 rep pointsninja500hs has between 5,000 and 7,500 rep pointsninja500hs has between 5,000 and 7,500 rep pointsninja500hs has between 5,000 and 7,500 rep pointsninja500hs has between 5,000 and 7,500 rep points
I have been using warm water and soap at home, but I recently discovered that I can also use lens cleaning wipes from ZEISS. Walmart sells those in a box for a reasonable price, and I throw a few in my tank bag. No streaks. Bugs will come right off with them, too.
ninja500hs is offline   Reply With Quote
