Helmet Visor Cleaning. - Page 3 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 12-04-2012, 01:59 PM   #21 (permalink)
Sev
The Indifference Engine
Sev's Avatar
Water and dish detergent (liquid kind) gently rub in with finger tips allow ad sspots to soak. You shouldn't be in a rush.
Sev is online now   Reply With Quote
Old 12-04-2012, 05:14 PM   #22 (permalink)
Yourworstnightmare Yourworstnightmare
Try out Stoner's Auto glass / plastic cleaner.
The shit works like a charm, and doesn't have ammonia or other harmful chemicals in it.
Yourworstnightmare is offline   Reply With Quote
Old 12-05-2012, 06:48 AM   #23 (permalink)
R1HOOLIGAN's Avatar
R1HOOLIGAN has at least 1500 rep pointsR1HOOLIGAN has at least 1500 rep pointsR1HOOLIGAN has at least 1500 rep pointsR1HOOLIGAN has at least 1500 rep pointsR1HOOLIGAN has at least 1500 rep pointsR1HOOLIGAN has at least 1500 rep pointsR1HOOLIGAN has at least 1500 rep pointsR1HOOLIGAN has at least 1500 rep pointsR1HOOLIGAN has at least 1500 rep pointsR1HOOLIGAN has at least 1500 rep pointsR1HOOLIGAN has at least 1500 rep points
Originally Posted by bRiT636 View Post
holy thread from the dead. I would have voted plexus, but have you seen the cost increase in the last few years...
NO KIDDING! I stocked up on Plexus a couple of years ago because I use it on my helmets and front end of the bikes (makes bugs just wipe right off). Saw a large can last week for $25....used to be half that!.....Hell, it's gettin' cheaper to eat money than buy groceries!
R1HOOLIGAN is offline   Reply With Quote
Old 12-05-2012, 12:04 PM   #24 (permalink)
Mibz has at least 10 rep points
I use the squeegee and paper towel at the gas station.
Mibz is offline   Reply With Quote
Old 12-05-2012, 02:10 PM   #25 (permalink)
Platinum Site Sponsor
RidersDiscount's Avatar
RidersDiscount has at least 1500 rep pointsRidersDiscount has at least 1500 rep pointsRidersDiscount has at least 1500 rep pointsRidersDiscount has at least 1500 rep pointsRidersDiscount has at least 1500 rep pointsRidersDiscount has at least 1500 rep pointsRidersDiscount has at least 1500 rep pointsRidersDiscount has at least 1500 rep pointsRidersDiscount has at least 1500 rep pointsRidersDiscount has at least 1500 rep pointsRidersDiscount has at least 1500 rep points
I think HJC says it best:
HJC does not recommend cleaning any shield with spray on type chemical cleaners. A reaction between shield and cleaning chemical is possible, resulting in haze build-up and distortion. HJC recommends washing the shield with warm water and soft cloth only. We also recommend cleaning the shield as soon as possible after dirt and debris have accumulated. Do not let debris sit on the shield for any extended period of time. If debris has accumulated over time, it is recommended to clean the shield in several applications. This allows the debris to break down with every application. Excessive rubbing can lead to scratching as the hard debris can act as a scuffing agent. The same can occur if low grade rigid paper towels are used.
Open Monday-Friday 10am-6pm EST
Call MIKE toll free at 866.931.6644 ext 804 OR his direct line at 616-965-2027
See what we're up to on facebook
Visit our website at Riders Discount
Ask me about our specials!
RidersDiscount is offline   Reply With Quote
Old 12-09-2012, 10:11 AM   #26 (permalink)
Sobe34 Sobe34
Here are a couple anti-fog products and visor cleaners I found! Anti-Fog - The Helmet Harbor, LLC
Sobe34 is offline   Reply With Quote
Old 12-10-2012, 04:50 AM   #27 (permalink)
Fairy Liquid if you have that.
It's also the best fog preventer I've found apart from a pin lock insert. Smear it on the inside of your visor (or glasses if you wear them), allow it to dry, then polish off. One application works for about a week of commuting in the rain.
Another tip - if you use a pinlock and need to remove that from the visor to wash it, after it's dry put it in a sealed plastic bag along with the visor and a sachet of silica gel and leave it overnight. The silica gel absorbs any remaining moisture so that when you refit the pin lock both it and the visor are bone dry.
Old 01-18-2013, 08:33 PM   #28 (permalink)
Sobe34 Sobe34
Found a discount code for HelmetHarbor.com. "Discount8"....just bought some gear and it worked ....
Old 01-22-2013, 11:23 AM   #29 (permalink)
Sobe34 Sobe34
