2004-2010 ZX-10R - $9 servo delete w/ FI light fix : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Go Back   KawiForums - Kawasaki Motorcycle Forums > Super Sport > ZX-10R
Old 05-29-2011, 05:14 AM   #1 (permalink)
No Regrets
Sly6r's Avatar
Location: Stuttgart, Germany By the way of Wheeling, WV Born and raised in the U.S.A. 2005 Kawasaki ZX-6R
Sly6r has between 5,000 and 7,500 rep pointsSly6r has between 5,000 and 7,500 rep pointsSly6r has between 5,000 and 7,500 rep pointsSly6r has between 5,000 and 7,500 rep pointsSly6r has between 5,000 and 7,500 rep pointsSly6r has between 5,000 and 7,500 rep pointsSly6r has between 5,000 and 7,500 rep pointsSly6r has between 5,000 and 7,500 rep pointsSly6r has between 5,000 and 7,500 rep pointsSly6r has between 5,000 and 7,500 rep pointsSly6r has between 5,000 and 7,500 rep points
Default 2004-2010 ZX-10R - $9 servo delete w/ FI light fix
This is a post I found on ZX-10r.net. I searched for something as clear as this, for a servo delete, on here and found nothing. This fix will work for 2004-2010 ZX-10R (more bikes below), according to the guys on the thread. I have no electrical experience...just putting this out there because it is good info. I included the original post, below, but please read the rest of the posts on ZX-10r.net, if you have any questions...here--> I Built My Own Servo Buddy For 9 Bucks. - Kawasaki ZX-10R.net
Link I posted on kawiforums for ZX-6R:
The bikes they say it will work on (same servo):
04-10 zx10r
05-2011 zx6r
06+ gsxr600
06+ gsxr750
05+ gsxr1000
Original Post:
As the title say's, I built my own servo buddy for 9 bucks.
UPDATE : This will work on the Gen 1, 2, & 3's. Don't know about the Gen 4 yet.
It has been said that this will work on the Gixxers too. But No proof of that as of yet.
I got a servo motor wire harness, purchased the pictured capacitor,
resistors, and epoxy. All for 9 bucks.
Just cut the wires off the servo motor.
1. I made up the capacitor / resistor circuit
Make sure the direction on the capacitor is correct / The arrows << on the Capacitor face the Black wire.
The resistors do not matter as far as the direction, they work either way.
Once you are sure about your circuit, solder it all together.
Then, mix up the epoxy in approx 1" W x 2" L x 1/2" D plastic tray,
it comes as part of the packaging of the epoxy.
Then submerse the servo buddy in the epoxy to where the top is covered.
This is for durability and insulation.
Once it has hardened and dried. Use a grinder or buffer to smooth
out any sharp edges or rough spots.
Next, wrap in electrical tape and plug it in.
I have installed this on my bike and
NO FI light after removing the servo motor.
I rode the bike for about an hour & 1/2 in all gears and throttle positions.
This actually works, and for 9 bucks.
Also, I gotta give PROPS to Racejunkie05 for showing me the circuit.
2004-2010 ZX-10R -  servo delete w/ FI light fix-1.jpg   2004-2010 ZX-10R -  servo delete w/ FI light fix-2.jpg   2004-2010 ZX-10R -  servo delete w/ FI light fix-3.jpg   2004-2010 ZX-10R -  servo delete w/ FI light fix-4.jpg   2004-2010 ZX-10R -  servo delete w/ FI light fix-5.jpg
:::No Regrets::: 05 ZX-6R (Raw Ti)
Metzeler M5's | Jardine Slip-on | Arrow headers | PCIII | Spiegler SS lines | Factory Pro Shift Star | 6000K HID Projectors | Scorpio Alarm | Integrated Smoked Tail & Turn | Corbin Seats | Yana Shiki shorty levers | Puig screen | K&N filter | OES sliders | Progrip grips | Jumper Mod | RAM GPS mount | Servo Buddy
Sly6r is offline   Reply With Quote
Old 05-29-2011, 05:15 AM   #2 (permalink)
No Regrets
Sly6r's Avatar
More pics.
2004-2010 ZX-10R -  servo delete w/ FI light fix-6.jpg   2004-2010 ZX-10R -  servo delete w/ FI light fix-7.jpg
Old 05-29-2011, 06:27 PM   #3 (permalink)
kaoss_11's Avatar
kaoss_11 has between 7,500 and 10,000 rep pointskaoss_11 has between 7,500 and 10,000 rep pointskaoss_11 has between 7,500 and 10,000 rep pointskaoss_11 has between 7,500 and 10,000 rep pointskaoss_11 has between 7,500 and 10,000 rep pointskaoss_11 has between 7,500 and 10,000 rep pointskaoss_11 has between 7,500 and 10,000 rep pointskaoss_11 has between 7,500 and 10,000 rep pointskaoss_11 has between 7,500 and 10,000 rep pointskaoss_11 has between 7,500 and 10,000 rep pointskaoss_11 has between 7,500 and 10,000 rep points
definately sticky worthy
Making love to the money cause thats my bitch.
kaoss_11 is offline   Reply With Quote
Old 06-02-2011, 02:32 AM   #4 (permalink)
No Regrets
Sly6r's Avatar
Bump.
Old 09-06-2011, 05:22 AM   #5 (permalink)
No Regrets
Sly6r's Avatar
Bump.
Old 09-06-2011, 11:21 AM   #6 (permalink)
Dragroc's Avatar
Dragroc has at least 3000 rep pointsDragroc has at least 3000 rep pointsDragroc has at least 3000 rep pointsDragroc has at least 3000 rep pointsDragroc has at least 3000 rep pointsDragroc has at least 3000 rep pointsDragroc has at least 3000 rep pointsDragroc has at least 3000 rep pointsDragroc has at least 3000 rep pointsDragroc has at least 3000 rep pointsDragroc has at least 3000 rep points
That guy was looking for a Gen 4 guinea pig to see if it works, I don't live far from him so I could technically contact him and go find out, but for anyone interested for the 2011-up models, the "reflash" can take care of the FI light for removal of the servo IF you tell them you want to delete it.
'11 10R
Dragroc is offline   Reply With Quote
Old 10-27-2012, 02:55 PM   #7 (permalink)
10R Rider has at least 10 rep points
04-10 zx10r
05-2011 zx6r
06+ gsxr600
06+ gsxr750
05+ gsxr1000
That design ONLY works on the 2004 thru 2010 ZX10R's.
It does not work on the ZX6R's.
Or the GSXR's, they just pull a pin on the ECU to eliminate the FI light.
There is a fix for the ZX6R's and Gen 4 (2011 & 12) ZX10R
But this one isn't it.
10R Rider is offline   Reply With Quote
Old 10-27-2012, 03:05 PM   #8 (permalink)
Hey Sly6r,
Do they still use the saying, "Bigger than Stuttgart" over there??
I was stationed in Darmstadt Germany in the mid 1980's.
And everyone used to say that when something was big.
Old 11-07-2012, 03:37 PM   #9 (permalink)
0410rSlim's Avatar
0410rSlim has at least 10 rep points
Works like a charm...thankz for saving me 50 bucks
Sent from my SAMSUNG-SGH-I747 using Motorcycle.com Free App
0410rSlim is online now   Reply With Quote
Old 01-15-2013, 04:54 AM   #10 (permalink)
Daw82 has at least 10 rep points
FI light? Hat are you talking about!
Daw82 is offline   Reply With Quote
