How to replace zx10 spark plugs - KawiForums - Kawasaki Motorcycle Forums
post #1 of 4 (permalink) Old 01-25-2006, 04:33 AM Thread Starter
gpz
Need to replace spark plugs and air filter on my 2005 zx10.
can anyone tell me step by step.
Thanks!
gpz is offline
post #2 of 4 (permalink) Old 01-26-2006, 12:26 PM
Send a message via Yahoo to mach_man_187
Change plugs already???? How many mile you got on it?
mach_man_187 is offline
post #3 of 4 (permalink) Old 01-26-2006, 03:54 PM
From what I ahve heard it is a pain in the ass, the motor mounts have to be disconnected and the motor dropper a little from the frame as the tow outside plugs are directly under the frame spars and can not be removed without doing this.
The airbox and air filter are not hard, remove the cover, pull the filter. Unbolt the 5 allen head bolts in the air trumpet area of the box and then unhook the ram air tubes from the box and shove them into the frame then turn the airbox 90 degrees inside of the frame and then it will come out.
I would go voer to ZX-10R.net and register over there and do a search as it was discussed over there not too long ago.
sneakyws6 is offline
post #4 of 4 (permalink) Old 01-27-2006, 08:21 AM Thread Starter
gpz
Thanks for the tip.
So you think I should just let the pros take care of it?
I wonder how much it costs.
I have 10650 miles on.
maybe I should wait for 15000.
what do you think.
gpz is offline
Closed Thread
