Go Back   KawiForums - Kawasaki Motorcycle Forums > Super Sport > ZX-12R
Old 08-06-2007, 08:03 PM   #1 (permalink)
99midnightZ's Avatar
99midnightZ has at least 10 negative rep points
Default port and polish head???? worth it???
my buddy has a zx12....and he is wanting to port and polish the head but was just currious what hp gains he could get and if its worth it...so ne one who has done it...i need your opinion...thanks
99midnightZ is offline   Reply With Quote
Old 08-14-2007, 06:38 PM   #2 (permalink)
Mike_C.'s Avatar
Mike_C. has at least 50 rep pointsMike_C. has at least 50 rep pointsMike_C. has at least 50 rep points
I dont know about the ZX12 but in general, yes porting and polishing the head is one of the oldest and best ways to get natural hp's out of an engine. Not many people do it now beacause tech. has gone past pulling the engine apart and just plug in a PC3 or other componants for fi bikes. Plus its big bucks to pay someone to do it who knows what they are doing. Lots of manuel labor. Its not something you want to try and find a good deal on even though Jose says that he can do it for 200 bucks in his shead in the back yard you dig?
Thats all I have to say about that
Mike_C. is offline   Reply With Quote
Old 08-31-2007, 05:39 AM   #3 (permalink)
ZXLNT is around zero rep points
Send a message via Yahoo to ZXLNT
Unless your doing other engine work with it like a big bore kit or stroker, I wouldn't mess with it..
ZXLNT is offline   Reply With Quote
Old 09-05-2007, 01:29 AM   #4 (permalink)
zx racer's Avatar
zx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep pointszx racer has between 5,000 and 7,500 rep points
u can make more HP out of your heads by porting and polishing, cams will wake a motor up, but if your not going to race the bike and just only street ride it, then i would say it's a waste of money to me, spend that money somewhere else on the bike besides the head
zx racer is offline   Reply With Quote
Old 01-09-2008, 01:28 AM   #5 (permalink)
Exhausted
Motowerkz's Avatar
Motowerkz Motowerkz Motowerkz Motowerkz Motowerkz Motowerkz Motowerkz Motowerkz Motowerkz Motowerkz Motowerkz
Porting your head??? Bigger is not always better. Porting might help to increase CFM but will reduce your intake velocity. Look at this picture from www.mototuneusa.com on how from the factory is increasing horsepower using the secrets from MotoGP and the AMA bikes(there making the intake ports smaller)...Left to Right-Stock, Race, 07' Race
Motowerkz is offline   Reply With Quote
Old 01-28-2008, 12:58 PM   #6 (permalink)
hiyaboa is around zero rep points
Send a message via AIM to hiyaboa
HAHAHAHA Not that website again....lol. I cant believe anyone actually believes that shit.
hiyaboa is offline   Reply With Quote
Old 01-28-2008, 01:08 PM   #7 (permalink)
AKA "White Dynamite"
mr.croom's Avatar
mr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep pointsmr.croom has between 20,000 and 30,000 rep points
Send a message via Yahoo to mr.croom
Polishing is always the way to go if you are uncertain about WHAT PARTS OF THE HEAD need to be ported. Smoothing the flow tract of the intake and exhaust is where the power is at. Lots of heads come polished from the factory nowadays.
http://i193.photobucket.com/albums/z158/mrcroom/croom_sig-2-1-1.jpg
mr.croom is offline   Reply With Quote
Old 03-22-2008, 06:17 PM   #8 (permalink)
Phantom13 has at least 10 rep points
You NEVER polish the intake side of the head.
Everything 9er said is 100% the truth.
The Stock ZX-12R CAN use a light "clean-up" in the ports along with some reshaping here and there.... but by no means does it need to be opened up unless you're increasing displacement. Either way, any kind of headwork is something you do on a racebike. If a little more power is what you're after, there's no better bang for the buck than a dry nitrous kit using a small and SAFE 20-30hp shot of nitrous. Just be sure to have the A/F and ignition timing properly set-up for it.
2003 Ace Performance Stage 2 R-Spec ZX-12R
ECTA #9577
205.6mph @ Maxton.... All Motor.
www.AcePeformanceRacing.com
Phantom13 is offline   Reply With Quote
Old 03-22-2008, 10:05 PM   #9 (permalink)
mr.croom's Avatar
Ok, I'll bite. Explain why you should NEVER polish the intake side of the cylinder head. I'm sure the Kawasaki factory would like to know as well, being that they started polishing intake ports from the factory, with the introduction of the 2005 ZX-6RR.
Old 03-24-2008, 09:38 PM   #10 (permalink)
A smooth surface, such as a polished one, creates puddling of fuel which leads to poor fuel atomization. Only the exhaust ports benefit from a polish.
You want fuel to break-up into the air for a more efficient burn, not drip down the ports.
The gains achieved via a more efficient fuel burn greatly outweight any miniscule increase in intake velocity achieved with polishing the intake ports. Polishing the intake is much like the saying, "Stepping over a dollar to pick up a dime."
btw, Kawasaki doesn't "polish" the intake ports, they hand finish them. There's a difference.
ECTA #9577
