Chain replaced not happy with master link install - Page 2 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 09-17-2012, 12:45 PM   #11 (permalink)
TJ Beavers
goingtoscotland's Avatar
Originally Posted by flaming06 View Post
every chain or ML I had ever bought were clip style so I considered it the "normal" kind I guess. Like I said the first rivet one I did on my bike was good. Then I bought new chain/sprockets and did another rivet. Im sure I didnt seat it good enough or whatever u want to call it but I broke it. More operator error than anything im sure.
636 chain break - YouTube
For a rivet style masterlink to fail it would have had to been improperly installed, or some sort of manufacturing defect.
Even properly installed clip style links will fail if you look at them sideways.
Originally Posted by Vrooming View Post
Masterlinks are like $50 right?
Masterlinks are like $7
Old 10-16-2012, 12:28 PM   #12 (permalink)
Strider007's Avatar
Strider007 has at least 500 rep pointsStrider007 has at least 500 rep pointsStrider007 has at least 500 rep pointsStrider007 has at least 500 rep pointsStrider007 has at least 500 rep pointsStrider007 has at least 500 rep pointsStrider007 has at least 500 rep points
Originally Posted by zx6rCarpz2k View Post
I have noticed since I replaced the chain and sprockets i can hear a whirling noise from that area... Could I have some other issue or does new chain have that sound like a whine sound?
It is normal for your new front sprocket to "whine" more than the stock one did, because the stock sprocket had a rubber damper on it that made it quieter. Most sprockets from other manufacturers don't have a damper, and they supposedly have less friction as a result, but also are a little noisier as well. I kinda like the way my new Vortex front sprocket purrs! =o)
2009 ZX-6R (32,000 miles and counting)
Strider007 is offline   Reply With Quote
Old 11-06-2012, 06:22 AM   #13 (permalink)
stanleyg stanleyg stanleyg
The picture looks really amazing. It costs around $6 to $8 initially. A replacement master link is really cheap and if you look for local motorcycle dealerships you can find the link easily. They really carry 520 pitch silver and gold links. You can easily run 525 or 520 stock size.
masterlink
stanleyg is offline   Reply With Quote
Old 11-07-2012, 10:38 PM   #14 (permalink)
zx6rCarpz2k's Avatar
zx6rCarpz2k is around zero rep points
[QUOTE=Strider007;2771434]It is normal for your new front sprocket to "whine" more than the stock one did, because the stock sprocket had a rubber damper on it that made it quieter. Most sprockets from other manufacturers don't have a damper, and they supposedly have less friction as a result, but also are a little noisier as well. I kinda like the way my new Vortex front sprocket purrs! =o)[/QUOTE
Ive noticed that on the new sprocket and also heard this somewhere before thanks for confirming my suspicions .
zx6rCarpz2k is offline   Reply With Quote
