Something's gone terribly wrong... (hole in piston) - KawiForums - Kawasaki Motorcycle Forums
post #1 of 11 (permalink) Old 11-04-2012, 11:45 PM Thread Starter
Vitruvius09's Avatar
So, I recently finished reassembling my engine. After some cranking (to be expected), it finally started. It seemed to run alright, but was making a significant rattling/ticking noise. The ticking was very consistent -- sped up and slowed down along with revs. I wasn't sure what to make of it. I know it wasn't the cam chain because I just replaced the tensioner. Anyway, after a few minutes of running, I heard a louder crack and it died. Pics below show what I found when I investigated. Note that the damage is only to cylinder 2, all of the others are completely fine.
What happened? Did I replace the cams incorrectly and cause a timing issue? Was there debris inside the cylinder? The hole in the piston doesn't appear to be burnt or melted...just punched through. Same goes for the spark plug. I'm just not sure what I did wrong.
Thanks for any insight!
ID:	52025   Click image for larger version
ID:	52026   Click image for larger version
Vitruvius09 is offline
post #2 of 11 (permalink) Old 11-05-2012, 12:37 AM
WCCoffey's Avatar
Send a message via AIM to WCCoffey
The hole is from the valve.
You messed up the timing, the piston hit the valve. Then in bent. Then it broke. Then it banged around in there and punched a hole.
That motor is junk now. Sorry!
ALWAYS check and double check your timing. Then spin the motor through by hand several times. If you don't feel any clearance issues then check the timing again and finish putting it together.
Sent from my GT-P3113 using Motorcycle.com Free App
Chris Coffey CMRA Racer #907
2014 Sponsors
Johnson Equipment Co - Norwood Auto Italia - Woodcraft CFM - Nexx Helmets - SouthCentralRaceCenter - Pirelli Tires - Racer Gloves USA
WCCoffey is offline
post #3 of 11 (permalink) Old 11-05-2012, 12:54 AM
This is why valve adjustments scare me and why I will probably never do one alone.
mikeurtno is offline
post #4 of 11 (permalink) Old 11-05-2012, 02:03 AM Thread Starter
Wouldn't the other cylinders have been affected if I replaced the cams wrong?
post #5 of 11 (permalink) Old 11-05-2012, 04:44 AM
Not necessarily. 3 teeth off on the cam chain and it'll just destroy the one cylinder.
Currently own:
05 Z750S
Have owned:
01 Volusia
Wrider is offline
post #6 of 11 (permalink) Old 11-05-2012, 12:52 PM
badassjake's Avatar
i'd suspect a rod failure, or if valve springs were removed, a keeper may have popped out....there should be impact marks from other valves touching the pistons, either intake or exhaust if it was drastically miss timed...
it's a 98-99 so parts should be plentiful and cheap
"Room for more with 674cc"-Book of Kawi 6:74
badassjake is offline
post #7 of 11 (permalink) Old 11-12-2012, 12:55 PM
badassjake's Avatar
...or a 95-97.
post #8 of 11 (permalink) Old 11-12-2012, 10:45 PM
av8r-92's Avatar
Yarp. No interest in fuckin' around in there.
-Will
av8r-92 is offline
post #9 of 11 (permalink) Old 11-13-2012, 11:06 PM Thread Starter
Yeah, I didn't touch the valves either. I only removed the cams so I could get to the head bolts. Valves scare me
post #10 of 11 (permalink) Old 11-13-2012, 11:22 PM
TimmaethBoy's Avatar
Anytime you disassemble an engine, always mark where the timing was prior to you fiddling around with it, not to mention following step by step in the manual.
Shit happens, sucks, but hopefully you learned from this.
TimmaethBoy is offline
