98 zx6r - KawiForums - Kawasaki Motorcycle Forums
post #1 of 10 (permalink) Old 12-12-2012, 04:42 PM Thread Starter
98 zx6r
I'm needing help finding tdc (top dead center) for my bike
audysain7 is offline
post #2 of 10 (permalink) Old 12-12-2012, 06:07 PM
manxchubba31's Avatar
Why do you need it?
manxchubba31 is offline
post #3 of 10 (permalink) Old 12-12-2012, 06:43 PM Thread Starter
98 zx6r g1. I have the cams, I just need the crankshaft
post #4 of 10 (permalink) Old 12-12-2012, 06:44 PM
You should be able to find a gauge. Are you willing to take the cylinder head off to check?
post #5 of 10 (permalink) Old 12-12-2012, 06:48 PM Thread Starter
yea that's no problem, where do i go from their
post #6 of 10 (permalink) Old 12-12-2012, 06:54 PM
Best thing to do is rotate the crank shaft by hand and when the piston reaches its furthest point away from the crank then that's your top dead centre which will be the same fore every cylinder. It should be anyway. The gauge should measure that and give you a figure. What do you need the tdc for anyway?
post #7 of 10 (permalink) Old 12-12-2012, 07:18 PM Thread Starter
alright, do I bring the two inside piston or the two outside piston farther away from the crankshaft
post #8 of 10 (permalink) Old 12-12-2012, 07:19 PM
Whichever is easier for you. 1 and 4 will probably be easier. I don't know how these gauges work but I have an idea so it should be fine. Why do you want to know the tdc?
Sent from my GT-I9300 using Motorcycle.com Free App
post #9 of 10 (permalink) Old 12-12-2012, 07:40 PM Thread Starter
I'm rebuilding my bike. I been putting it all back together and it says what the cams should be set at in my manuals but not the crankshaft
post #10 of 10 (permalink) Old 12-12-2012, 07:46 PM
You need to know the tdc so it's in time with the rest of the firing sequence? Right makes sense. You probably don't need a gauge then really if you have a play around but there should be instructions on tinterweb somewhere
