So on an impulse purchase I bought a 1989 Ninja 600R. I knew there were motor issues but figured worse case I would just part it out what I cant use on another project. Well it may come to that worse case scenario.
Pulled off the the covers and fairing today to find a lovely hole in the motor case with a rod peaking out of it. So.... my questions; Are there any other Kawasaki's that used that same engine or are there any other variations that will bolt into that frame and use the same harness and electronics? Just seeing if there is so I might be able to widen my search for a donor. If not then Ill probably just end up parting it out and also seeing if the fork and swing arm could be adapted to work with my cafe project.
Thanks! :smile2:
Thanks! :smile2:
