Upper cam chain guide disintegrated : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Go Back   KawiForums - Kawasaki Motorcycle Forums > Super Sport > ZX-7R & ZX-9R > ZX-7R
Old 11-18-2012, 03:36 PM   #1 (permalink)
01ragtop has at least 10 rep points
Default Upper cam chain guide disintegrated
I recently acquired a 2000 ZX7R with about 20,000 miles. I have been riding it, but I decided to get on with the maintenance, so this morning I tore down the top end to get a look at the valve clearances. Once I got the valve cover off, however, I noticed a couple of little black plastic bits just sitting on top of the head. A couple more were found when I pulled the cover off of the coil pick up sensor. I did some reading and figured it must be the upper cam chain guide, and sure enough, it is completely missing from under the valve cover.
Problem is, though, I did not find enough plastic bits to make up an entire guide. Far from it actually, so I am thinking this thing must be floating around inside the engine.
I did a search about this and found this post:
Upper Cam Chain Guide Broken into pieces.
But it sounds like the people in this post were lucky in that they found the whole piece. I didn't and I am wondering if anyone has ran across just a few pieces and what they did. I was thinking that I may need to drop the pan, but if I don't find the rest of the pieces in there, then what should I do?
Any help is greatly appreciated.
-Dan
01ragtop is offline   Reply With Quote
Old 11-19-2012, 06:01 PM   #2 (permalink)
jbreit's Avatar
jbreit has between 10,000 and 20,000 rep pointsjbreit has between 10,000 and 20,000 rep pointsjbreit has between 10,000 and 20,000 rep pointsjbreit has between 10,000 and 20,000 rep pointsjbreit has between 10,000 and 20,000 rep pointsjbreit has between 10,000 and 20,000 rep pointsjbreit has between 10,000 and 20,000 rep pointsjbreit has between 10,000 and 20,000 rep pointsjbreit has between 10,000 and 20,000 rep pointsjbreit has between 10,000 and 20,000 rep pointsjbreit has between 10,000 and 20,000 rep points
I found the remnants of mine down by the pick-up, behind the cover on the end of the crank. I think they broke loose when I was taking the cover off, I hadn't even noticed it until later...
From there to the pan is a short trip. If you drain the pan it may carry pieces in there out with it. The oil sump has a screen on in the inlet....it won't go past there. If it were mine, I might not even drop the pan depending on how much is MIA....find what I could and move on.
whitey (whitehendrix) has probably seen the most of of this...perhaps he'll chim in.
jbreit is offline   Reply With Quote
