Go Back   KawiForums - Kawasaki Motorcycle Forums > Super Sport > ZX-9R
Old 01-15-2009, 07:04 PM   #1 (permalink)
kawi9's Avatar
kawi9 has at least 500 rep pointskawi9 has at least 500 rep pointskawi9 has at least 500 rep pointskawi9 has at least 500 rep pointskawi9 has at least 500 rep pointskawi9 has at least 500 rep points
Default ZX9R Turbo winter upgrade (Stretch)
Hi,
I working again for upgrade my ZX9R Turbo. I stretch my bike with bolt on extension swingarm (3-7inches). This setup will be for race with higher boost 14-15 psi on pump fuel. With this swingarm extension, i will may use all gears until the red line without than the front wheel lift.
I installed my extension, but not finished. It's just for see if the parts are ok and if it's fit good. I would like to know what is the good torque for the bolt on the swingarm extention ? Because it's use kit and i don't have this information.
Also, i search a use ZX9R 02-03 swingarm with axle, shock, link and complete rear brake all in good condition for fit my extension.
This is some pics and i will post more pics when i will progress
kawi9 is offline   Reply With Quote
Old 01-15-2009, 09:26 PM   #2 (permalink)
whitehendrix's Avatar
Location: Wilmington, Nc.. trying not to crash any more
MAN.. i love the stretch, but i'm not a big fan of bolt-on stuff.
it just scares me.
regardless, it DOES look awesome!!
nice.
couldn't tell ya a torque.. maybe 50 ft-lbs? i'd go til it feels good n tight.. maybe use a mild strenth threadlocker on it just for fun..
good luck!
▲shuttin down noob "techs" one post at a time▲
Need A "How To"?-USE THIS MOTHERFUCKING LINK!!!!! http://www.kawiforums.com/how-tos-fa...avigation.html
Sept09 B.O.T.M. winner avatar not under my control...
Old 01-16-2009, 04:11 AM   #3 (permalink)
Ditch Ninja has at least 10 rep points
they look good man but with that amount of power at the rear. the ? is are they made for that kind of abuse or are they suppose to just look cool
Green tires make you go faster
2000 ZX9r
Ditch Ninja is offline   Reply With Quote
Old 01-16-2009, 12:59 PM   #4 (permalink)
Tough-Guy's Avatar
Tough-Guy has between 10,000 and 20,000 rep pointsTough-Guy has between 10,000 and 20,000 rep pointsTough-Guy has between 10,000 and 20,000 rep pointsTough-Guy has between 10,000 and 20,000 rep pointsTough-Guy has between 10,000 and 20,000 rep pointsTough-Guy has between 10,000 and 20,000 rep pointsTough-Guy has between 10,000 and 20,000 rep pointsTough-Guy has between 10,000 and 20,000 rep pointsTough-Guy has between 10,000 and 20,000 rep pointsTough-Guy has between 10,000 and 20,000 rep pointsTough-Guy has between 10,000 and 20,000 rep points
Looks like billet T6. He'll be fine.
Thou shall recieve no tech from I, foul Sirs.
- I told you not to fuck with K-TRIK because it is watching you and knows all. But NNNOOOOOO, you assholes didn't want to listen.
Tough-Guy is offline   Reply With Quote
Old 01-16-2009, 01:40 PM   #5 (permalink)
yeah he should be. so kawi 9 you going to switch those blinkers and what not to make it look as bad ass as the power your putting out.
were did you find the those at man
2000 ZX9r
Old 01-16-2009, 09:20 PM   #6 (permalink)
it's definitely a billet piece.
whether its 6061 or 7075 and if the temper is T4 T5 or T6 is up to the spec sheet!!!
T6511 6061 aluminum has a tensile strength of i think 48Kpsi
7075 when tempered to T6 is 120Kpsi!!!
only thing is, you can't weld 7075. you CAN weld 6061.. so if one were to buy bolt-on extentions with the idea of welding them and permanaently affixing them to the stock swinger, they'll be sorely dissapointed if they were crafted from the aircraft-grade stuff.
and so ends your tiny metallurgy lesson for the day.
Old 01-17-2009, 12:05 PM   #7 (permalink)
kawi9's Avatar
I bought the extension swingarm on Ebay and they can support big horsepower. Because, i know a guy run 300+whp with swingarm extension without problem. I will run with extension for race. I don't think run on daily ride.
Old 01-27-2009, 05:36 PM   #8 (permalink)
Fast Jetta 97's Avatar
Fast Jetta 97 has at least 500 rep pointsFast Jetta 97 has at least 500 rep pointsFast Jetta 97 has at least 500 rep pointsFast Jetta 97 has at least 500 rep pointsFast Jetta 97 has at least 500 rep pointsFast Jetta 97 has at least 500 rep points
thats freekin siack man....
I LOVE TURBO BIKES....
nice work.... post more pics if you got em....
00' ZX-9 (stunt)
99' CBR 900 rr
Jetta VR-6 Turbo
Fast Jetta 97 is offline   Reply With Quote
Old 01-27-2009, 07:43 PM   #9 (permalink)
kilaman's Avatar
kilaman has at least 500 rep pointskilaman has at least 500 rep pointskilaman has at least 500 rep pointskilaman has at least 500 rep pointskilaman has at least 500 rep pointskilaman has at least 500 rep points
Send a message via Yahoo to kilaman
I have seen hairline cracks on extentions on my friends zx12. 2000 model with a small overbore.
01 ZX9R 998cc kit, Ti Full Muzzy exhaust, OZ Racing Wheels, BMC Race filter, -1/+3 520 conv , +4 timing
01 GSXR750R 05 R1 trackbike
01 KSF250 Mojave
kilaman is online now   Reply With Quote
Old 05-06-2009, 07:03 PM   #10 (permalink)
kawi9's Avatar
I show some progress of my extended project. I bought a ZX9 swingarm 02-03 and shock and link, complet rear brake with pedal on ebay. I finished to repaint the swingarm and extension. The result is good.
I bought a long chain EK ZZZ 530 and a new front sprocket Vortex 18 teeth (+2). I have many combo of sprockets front 16-17-18 and rear 38-41-44. The 18 T sprocket is for top speed run.
