fuel pump won't turn on. - KawiForums - Kawasaki Motorcycle Forums
post #1 of 11 (permalink) Old 06-05-2009, 05:02 PM Thread Starter
The pump works when i connect it directly to the battery.
When the key is turned the pump does not prime or turn on.
I just checked all the wires associated for connectivity, no problem.
Tried a new fuel pump relay. same result. nothing.
Help?
goof4080 is offline
post #2 of 11 (permalink) Old 06-05-2009, 05:12 PM
Powerhungry
nevada's Avatar
kill switch on?
ERIN
nevada is offline
post #3 of 11 (permalink) Old 06-05-2009, 05:16 PM Thread Starter
Originally Posted by nevada View Post
kill switch on?
bike will start and run, but poorly. fuel pump never turns on or primes.
goof4080 is offline
post #4 of 11 (permalink) Old 06-05-2009, 05:20 PM
Powerhungry
nevada's Avatar
how does the bike start and run if the fuel pump doesnt turn on?
ERIN
nevada is offline
post #5 of 11 (permalink) Old 06-05-2009, 05:43 PM Thread Starter
it's carbed, but has a fuel pump. i dunno.
goof4080 is offline
post #6 of 11 (permalink) Old 06-05-2009, 08:08 PM
tchavis05's Avatar
If the bike is running , the fuel pump is working.
tchavis05 is offline
post #7 of 11 (permalink) Old 08-05-2009, 09:07 AM
Ever heard of vacuum and gravity? I'm not exactly sure, does anyone else know?
kickinkid21 is offline
post #8 of 11 (permalink) Old 08-05-2009, 01:22 PM
badassjake's Avatar
the pump doesn't pump and prime till the start button is pressed(and only when pressed and bike is running)....take the fuel pump off and remove the black cover, there is a set of points in there....clean and file them.....make sure the inline small filter at the spot where you connect the fuel line to the carbs isn't full of real small crap, restricting flow.
J
"Room for more with 674cc"-Book of Kawi 6:74
badassjake is offline
post #9 of 11 (permalink) Old 08-06-2009, 09:41 PM
Hi,
What badassjake said is exactly right.
I had the same prob. Bike started, idle'd and just died. Never turn on after that.
I stripped it down to fuel pump, pulled it apart and also (yes, tastes crap) sucked and blew into the pump to make sure it still pumps, and now its been running fine for over 8 months. Never touch it since.
Replace your filter too, and just double check your fuel line for a blockage. It could be blocked up and not letting fuel flow properly, which is why it works on startup only.
kingoddball is offline
post #10 of 11 (permalink) Old 08-06-2009, 09:53 PM
Send a message via AIM to zzr600187
fuel pump relay lil black box on the left part of the subframe between the tail should have a lil rubber strap holding it still should be by 2 fuses
zzr600187 is offline
