fuel pump won't turn on. : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 06-05-2009, 05:02 PM   #1 (permalink)
goof4080 has between 50 and 100 negative rep points
Default fuel pump won't turn on.
The pump works when i connect it directly to the battery.
When the key is turned the pump does not prime or turn on.
I just checked all the wires associated for connectivity, no problem.
Tried a new fuel pump relay. same result. nothing.
Help?
goof4080 is offline   Reply With Quote
Old 06-05-2009, 05:12 PM   #2 (permalink)
Powerhungry
nevada's Avatar
kill switch on?
ERIN
Old 06-05-2009, 05:16 PM   #3 (permalink)
Originally Posted by nevada View Post
kill switch on?
bike will start and run, but poorly. fuel pump never turns on or primes.
Old 06-05-2009, 05:20 PM   #4 (permalink)
Powerhungry
nevada's Avatar
how does the bike start and run if the fuel pump doesnt turn on?
ERIN
Old 06-05-2009, 05:43 PM   #5 (permalink)
it's carbed, but has a fuel pump. i dunno.
Old 06-05-2009, 08:08 PM   #6 (permalink)
tchavis05's Avatar
tchavis05 has at least 250 rep pointstchavis05 has at least 250 rep pointstchavis05 has at least 250 rep pointstchavis05 has at least 250 rep points
If the bike is running , the fuel pump is working.
tchavis05 is offline   Reply With Quote
Old 08-05-2009, 09:07 AM   #7 (permalink)
kickinkid21 has at least 10 rep points
Ever heard of vacuum and gravity? I'm not exactly sure, does anyone else know?
kickinkid21 is offline   Reply With Quote
Old 08-05-2009, 01:22 PM   #8 (permalink)
badassjake's Avatar
badassjake has between 7,500 and 10,000 rep pointsbadassjake has between 7,500 and 10,000 rep pointsbadassjake has between 7,500 and 10,000 rep pointsbadassjake has between 7,500 and 10,000 rep pointsbadassjake has between 7,500 and 10,000 rep pointsbadassjake has between 7,500 and 10,000 rep pointsbadassjake has between 7,500 and 10,000 rep pointsbadassjake has between 7,500 and 10,000 rep pointsbadassjake has between 7,500 and 10,000 rep pointsbadassjake has between 7,500 and 10,000 rep pointsbadassjake has between 7,500 and 10,000 rep points
the pump doesn't pump and prime till the start button is pressed(and only when pressed and bike is running)....take the fuel pump off and remove the black cover, there is a set of points in there....clean and file them.....make sure the inline small filter at the spot where you connect the fuel line to the carbs isn't full of real small crap, restricting flow.
J
"Fast,light and fun with 751."- Book of Kawi 7:51
badassjake is offline   Reply With Quote
Old 08-06-2009, 09:41 PM   #9 (permalink)
kingoddball has at least 10 rep points
Hi,
What badassjake said is exactly right.
I had the same prob. Bike started, idle'd and just died. Never turn on after that.
I stripped it down to fuel pump, pulled it apart and also (yes, tastes crap) sucked and blew into the pump to make sure it still pumps, and now its been running fine for over 8 months. Never touch it since.
Replace your filter too, and just double check your fuel line for a blockage. It could be blocked up and not letting fuel flow properly, which is why it works on startup only.
kingoddball is offline   Reply With Quote
Old 08-06-2009, 09:53 PM   #10 (permalink)
zzr600187 has at least 250 rep pointszzr600187 has at least 250 rep pointszzr600187 has at least 250 rep pointszzr600187 has at least 250 rep points
Send a message via AIM to zzr600187
fuel pump relay lil black box on the left part of the subframe between the tail should have a lil rubber strap holding it still should be by 2 fuses
zzr600187 is offline   Reply With Quote
Yamaha Motorcycles Victory Gunner Forum Victory Charger Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum
Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
