well polishing the wheels and swingarm aint to bad because there chrome so a lil foam glass cleaner and wipe it down. keeping up on the aluminum subframe takes some work, but maybe once a month is all it really needs. the wheels r from rc components had to get a hub made for the front wheel to work. unfortunaly the rear wheel was rubbing the chain by lik 1mm and put a few scars on the outter lip. i told the guy it needed more clearance he said he did but it wasnt enough... i might have to file down the inside of the frame like 1-2mm where the chain goes into the frame to the front sprocket. that way i can shim the rear sprocket out a lil more. its a tight squeeze with the 530 chain. i have a headlight mounted into the air damn of the front cowl hidden behind a mesh screen. so it looks like theres no light. i have no front blinkers.
