My bikes mods. - Page 99 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 11-03-2012, 07:25 PM   #981 (permalink)
arron's Avatar
arron has at least 500 rep pointsarron has at least 500 rep pointsarron has at least 500 rep pointsarron has at least 500 rep pointsarron has at least 500 rep pointsarron has at least 500 rep points
nice set up michael.. I too will have to get a carb tuner 1 day but for now the ol atf works good enough for me.. Why do you need to do that at the start if all the 4 blue tubes are in there own section? might a stupid question cos i have never used 1 before
arron is offline   Reply With Quote
Old 11-04-2012, 06:13 AM   #982 (permalink)
It's not rocket surgery.
LarryJ's Avatar
Aaron you calibrate the tool that way. Connecting the four tubes to one vacuum port allows you to set all four tubes the same. When you hook up one tube to each vacuum port then when you since the carbs you know you're getting equal vacuum draw in each cylinder. Hopefully that makes sense.
Old 11-04-2012, 04:19 PM   #983 (permalink)
arron's Avatar
Are the 4 blue tubes sealed from each other or are they joined?
Old 11-05-2012, 12:56 PM   #984 (permalink)
Maness1220's Avatar
Maness1220 has between 10,000 and 20,000 rep pointsManess1220 has between 10,000 and 20,000 rep pointsManess1220 has between 10,000 and 20,000 rep pointsManess1220 has between 10,000 and 20,000 rep pointsManess1220 has between 10,000 and 20,000 rep pointsManess1220 has between 10,000 and 20,000 rep pointsManess1220 has between 10,000 and 20,000 rep pointsManess1220 has between 10,000 and 20,000 rep pointsManess1220 has between 10,000 and 20,000 rep pointsManess1220 has between 10,000 and 20,000 rep pointsManess1220 has between 10,000 and 20,000 rep points
There sealed from one another.
& Larry was spot on with his description.
Double WINNER Aug 2010 Aug 2011, 6OTM @ ZX6R.com & Feb ROTM winner @ ZXforums.
"He who lives by the sword,
Will need to practice with it often."
Maness1220 is offline   Reply With Quote
Old 11-05-2012, 03:59 PM   #985 (permalink)
arron's Avatar
Cool thanks guys. Was just wondering you need to sync them if there individual tubes. Thanks again
Old 11-08-2012, 04:02 AM   #986 (permalink)
LarryJ's Avatar
Yeah you use one cylinder as a reference point so you know all four tubes read the same. There are adjusters to allow you to adjust fluid height, so you hook up all four tubes to one vacuum port then adjust each screw on the tool to get the same reading across the board. Now that you've done that, when you hook the tool up one tube to each cylinder and adjust the butterfly valves you know they're all drawing the same vacuum.
Old Today, 03:59 PM   #987 (permalink)
Maness1220's Avatar
Default & Just to breath new life into this old thread...
