+4 advancer - KawiForums - Kawasaki Motorcycle Forums
post #1 of 24 (permalink) Old 07-06-2010, 04:32 AM Thread Starter
arron's Avatar
+4 advancer
Looking at getting a +4 advancer for my G1 and was wondering if you need the carbs rejetted? The bike has -1 front and stock rear sprocket, jardine can and k&n air filter.. If i do need the carbs jetted what should size jets or kit if the best or easyist as well to do..
arron is offline
post #2 of 24 (permalink) Old 07-06-2010, 04:29 PM
Tober113's Avatar
With all those current mods how does she run? I would think your bike already needs rejetting.
Tober113 is offline
post #3 of 24 (permalink) Old 07-06-2010, 04:54 PM
Maness1220's Avatar
Iv got one & never rejetted. Its only a Small advance in timing.
I don't think it requires rejetting. I could be wrong.????????
"He who lives by the sword,
Will need to practice with it often."
Maness1220 is offline
post #4 of 24 (permalink) Old 07-06-2010, 05:10 PM
Amby01's Avatar
No rejetting is needed if you go to +4. If you got any bigger than that you do need to rejet. I have one on my bike as well....
Amby01 is offline
post #5 of 24 (permalink) Old 07-06-2010, 05:18 PM
make much of a difference?if so where and how much?
98Ninja6 is offline
post #6 of 24 (permalink) Old 07-06-2010, 05:38 PM
Maness1220's Avatar
Dennis Kirk, Solomoto, $55.00. Not a lot of deference, But noticeable.
IMHO a good carb sync & valve adjustment will do more for your bike.
post #7 of 24 (permalink) Old 07-06-2010, 08:29 PM
How is moving up the timing a cause a rejet?? You are not moving more air in or out of the motor so your AF will still be the same.... All you are doing with it is creating a longer burn in the combustion chamber. ie. a more efficient burn
144dbFiBl15 is offline
post #8 of 24 (permalink) Old 07-07-2010, 01:04 AM Thread Starter
arron's Avatar
i got it from here Bike Gear Warehouse : Motorcycle Gear, Parts and Accessories Wholesale Direct to Public for $49.. Bike did run good till i got some crap gas and blocked 1 jet solid and then i cleaned the carbs and got it back together again and rus a bit ruff now.. needs a good tune now.. gunna put the +4 and get the local bike guru do do a rejet and dyno tune in a couple of weeks.. Whats a good jet kit?
arron is offline
post #9 of 24 (permalink) Old 07-07-2010, 07:44 AM
WildCard's Avatar
Dyno Jet
damned. " - WillBrink
WildCard is offline
post #10 of 24 (permalink) Old 07-07-2010, 07:49 AM
Jeff in Kentucky's Avatar
At least two other companies besides Dynojet sell jet kits- Ivans and Factory Pro. I'm not sure which is best- it would probably take comparing race track or drag race times, and depends on your exhaust and intake changes.
Jeff in Kentucky is offline
