ZZR600 Top Speed - KawiForums - Kawasaki Motorcycle Forums
post #1 of 61 (permalink) Old 10-12-2010, 05:51 PM Thread Starter
ZZR600 Top Speed
Anyone know what the expected top speed is on a stock ZZR600. I am seeing some people claim around 175 MPH and some people saying thats impossible. Anyone done a top speed run on a ZZR? I am talking top speed meaning there was literally 0 speed left to gain even after a minute or so.
Anile8er is offline
post #2 of 61 (permalink) Old 10-12-2010, 06:08 PM
mine does 180 lol
you can't trust stock speedos and the geering doesn't allow much over 155 if i remember right( the gearcalc program seems to have vanished). stock gearing, diameter of the wheel, rpm and reduction ratios can't lie and a wind behind isn't gonna do that much.
non stock sprockets and geerbox on a good day downhill and you'll probably get 200+ if the wind doesn't blow you or the fairings off
98Ninja6 is offline
post #3 of 61 (permalink) Old 10-12-2010, 06:14 PM Thread Starter
Is yours stock and your able to get 180mph lol. How much do you weight?
Anile8er is offline
post #4 of 61 (permalink) Old 10-12-2010, 07:05 PM
The top speed of the kawasaki ZZR600 is around 140 but the max speed is 240, so you can ride upto 240 ...
charliebrown408 is offline
post #5 of 61 (permalink) Old 10-12-2010, 08:04 PM
Missingparts's Avatar
From personal experience I know that with -1 +2 gearing it will pull to redline in 6th gear which should be right at 164mph. It would go faster with different gearing but prolly not by much.
Missingparts is offline
post #6 of 61 (permalink) Old 10-12-2010, 08:21 PM
IRONJUNGLE.COM
cool, it still exists
Primary reduction ratio
2.022 (89/44)
Gear ratios:
1st 2.923 (38/13)
2nd 2.062 (33/16)
3rd 1.631 (31/19)
4th 1.380 (29/21)
5th 1.217 (28/23)
6th 1.083 (26/24)
Final reduction ratio 2.666 (40/15)
for the J1 - i'm not sure the exact rear tyre size so best to measure as they are all different
60% of 170mm in inches is approx 4 - (3+3) + 17 x 3.14 = 72 inches
so absolutely flat out 14,500 rpm redline in 6th equals 169mph with 60mph at approx 5100rpm (13500rpm is about 157mph)
-1/+2 = 14/42 = 150mph redline.
98Ninja6 is offline
post #7 of 61 (permalink) Old 10-12-2010, 08:23 PM
Timmymoto's Avatar
Max power is supposed to be in the 12,500-13,000 rpm range so around 160mph with stock gearing. check it out here. Gearing Commander: Motorcycle Gear Ratio Calculator for Sprockets RPM Speed Chain
Timmymoto is offline
post #8 of 61 (permalink) Old 10-12-2010, 08:47 PM
roadrash32433's Avatar
2000 Kawasaki ZX-6R Ninja specifications and pictures
they're claiming 158.4 mph stock
It's a beautiful day!!!
'02 ZX6R-M4 exhaust, Stage II Factory jet kit, Sprockets: -1 front, +5 rear, K&N air filter, Zero Gravity double bubble, carbon fiber sliders and levers, pro grips, integrated smoked tail light and rear hugger!!!
roadrash32433 is offline
post #9 of 61 (permalink) Old 10-12-2010, 08:50 PM
seems many zx6's defy the laws of physics
+2/-2 or 17/38 is over 201mph but the little 600 motor and 90's aerodynamics would never get there
98Ninja6 is offline
post #10 of 61 (permalink) Old 10-12-2010, 09:27 PM
scottynoface's Avatar
About 160, same as most other 600s.
2003 ZX636R - Now in pieces
2000 RM 125 - Waiting to tear down again
scottynoface is offline
