09/10 ZX6R Swingarm, not a bolt on : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 12-06-2010, 01:38 PM   #1 (permalink)
ttr50rider12 has at least 4000 rep pointsttr50rider12 has at least 4000 rep pointsttr50rider12 has at least 4000 rep pointsttr50rider12 has at least 4000 rep pointsttr50rider12 has at least 4000 rep pointsttr50rider12 has at least 4000 rep pointsttr50rider12 has at least 4000 rep pointsttr50rider12 has at least 4000 rep pointsttr50rider12 has at least 4000 rep pointsttr50rider12 has at least 4000 rep pointsttr50rider12 has at least 4000 rep points
Send a message via AIM to ttr50rider12
Default 09/10 ZX6R Swingarm, not a bolt on
Well, i had posted awhile back that i had purchased a 09 ZX6R Swingarm off Ebay, but never had any time or ambition to do anything with it, well, i finally decided to pull out my spare frame and check it out. Unfortunately it will not work without some machine work. I personally will not be doing the swap, because after i put the work into it to get it to fit, then i need to remake my exhaust again which i don't want to do as i have undertail exhaust.
Why it does not bolt on you ask? Well, the pivot point is too wide, its about an inch wider then the 98-08 swingarms, so you have a few options, and the easiest being remove the material from the pivot point of the frame where it protrudes from the spars. But if you do this, then there is no going back (well unless you make spacers for the old arm to go back). You could remove the material from the arm, but how its setup, you would have to do some serous work as you would then need to make bearing collars etc.
So ask yourself this, is it worth it? Well thats up to you, but for me, the work is not worth the time as i am taking a gamble as it is with trying to fit up an undertail pipe through where the shock mounts.
Ben
-98 ZX6R, Mostly Stock... Stay Tuned, one last frame over renovation, bigger and more bad then ever before...
ttr50rider12 is offline   Reply With Quote
Old 12-10-2010, 01:04 PM   #2 (permalink)
It's not rocket surgery.
LarryJ's Avatar
Hmm. Yeah sounds like way too much work, and I doubt there's a benefit in having it in opposed to the 05-08. Too bad though man, but thanks a lot for letting us know.
Old 12-10-2010, 03:42 PM   #3 (permalink)
Well, yeah other then looks theres no real advantage of it over the 05-08 swingarms. I was hoping it would fit up because i really like the look, but oh well.
Ben
Old 12-10-2010, 03:43 PM   #4 (permalink)
LarryJ's Avatar
Ben
Oh yeah I'm right with you on the look aspect. I like the hugger that came with that bike, too. Oh well.
Old 12-10-2010, 06:06 PM   #5 (permalink)
badassjake's Avatar
badassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep points
sounds like a slick conversion possibility for the 98-03 ZX9R....someone may jump on that wagon.
"There is always room for more with 674."- Book of Kawi 6:74
badassjake is offline   Reply With Quote
Old 12-30-2010, 10:12 PM   #6 (permalink)
aftermarketguy's Avatar
aftermarketguy has at least 10 rep points
So.....let me get this straight (sorry, I never did a full search on this)....for my '00 ZX6R, I can use a swingarm from any ZX6R 2008 or older???
aftermarketguy is offline   Reply With Quote
Old 01-07-2011, 04:48 AM   #7 (permalink)
LarryJ's Avatar
True. With the '05-'08 swingarms though you'll need a longer rear brake line and shave down wheel spacers if you decide to keep your stock 3-spoke wheel. The newer 5-spoke have a skinnier hub than the 3-spoke. But the swingarm pivot will bolt right up to your frame. This thread has all the info you need concerning your bike: Master Parts Swap List Ver2.0 98+ ZX6R
If you have any more additional questions, feel free to PM ttr50rider12. He's more than happy to answer any questions you have. All the stuff he talks about he's actually done himself and/or done measurements to ensure fitment.
Old 11-04-2012, 02:31 AM   #8 (permalink)
arron's Avatar
arron has at least 500 rep pointsarron has at least 500 rep pointsarron has at least 500 rep pointsarron has at least 500 rep pointsarron has at least 500 rep pointsarron has at least 500 rep points
I'm about to do a swing arm conversion on my 98 with a 08 swinger and keep my 3 spoke wheels for now.. How much do I need to shave the spacers down?
arron is offline   Reply With Quote
Old 11-04-2012, 06:19 AM   #9 (permalink)
LarryJ's Avatar
Ask Maness, he knows how much to trim everything. The 07/08 swing arm is a little longer than the 05/06 but the dimensions at the wheel mount are exactly the same.
Old 11-04-2012, 09:10 AM   #10 (permalink)
Crazy1's Avatar
Crazy1 has at least 500 rep pointsCrazy1 has at least 500 rep pointsCrazy1 has at least 500 rep pointsCrazy1 has at least 500 rep pointsCrazy1 has at least 500 rep pointsCrazy1 has at least 500 rep points
Im going to do this mod on mine, so thanks for the info TT.
Just one question, is the width at the wheel pivot point the same as the 05-08 swinging arms?
Crazy1 is offline   Reply With Quote
