Time to make some changes. - Page 9 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 08-07-2012, 06:16 PM   #81 (permalink)
basco's Avatar
basco has at least 50 rep pointsbasco has at least 50 rep pointsbasco has at least 50 rep points
Lookin good Jake!! must be a hell of a ride with a 674 in a J model
2005 ZZR600: Daily- Scorpion Ti Oval, K&N Filter, Dynojet Stg. 1
2001 Buell Cyclone: track whore
basco is offline   Reply With Quote
Old 08-24-2012, 03:29 PM   #82 (permalink)
badassjake's Avatar
badassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep pointsbadassjake has between 5,000 and 7,500 rep points
just reweighed the bikes for consisten matters.....the 6R tipped the scales at 390lbs with a full tank of gas.....15L @ 1-1.5lbs per liter....that gives a dry-ish weight of 370-375lbs.
Surprisingly not much heavier then the "6RR"(as I am calling it)
Got a decent tune in it finally......effortless gas wheelies in 2nd gear....effortlessly accelerates to redline in 6th
Impressed with the performance...taking it drag racing in two weeks, so I can get a so-so relation to how well my big-carbed 636cc motor worked against this version .....time to beat, 10.77s
"There is always room for more with 674."- Book of Kawi 6:74
badassjake is offline   Reply With Quote
Old 10-05-2012, 03:44 PM   #83 (permalink)
badassjake's Avatar
well, was not impressed with the on/off throttle without the secondary injectors....boredome got me, so I finally rigged up the secondary injectors into the airbox and went back out and got a good tune made for it..... WAYYY better....
Took some time and re-angled my exhaust for the intended lines and flow of the bike..will take a revised pic.
Old 10-05-2012, 06:47 PM   #84 (permalink)
It's not rocket surgery.
LarryJ's Avatar
Old 10-06-2012, 05:47 PM   #85 (permalink)
badassjake's Avatar
like this.........
Time to make some changes.-wp_000405.jpg   Time to make some changes.-wp_000406.jpg
Old 10-18-2012, 03:32 AM   #86 (permalink)
badassjake's Avatar
spacer plate for the block ordered.....crank to be sent out to get massaged.....
Super-secret-squirrel-sh$t going on
Old 12-09-2012, 02:14 PM   #87 (permalink)
badassjake's Avatar
crank on route for some stroking........gonna be making what Kawi should have made back in mid 2000
Old 03-23-2013, 08:39 AM   #88 (permalink)
badassjake's Avatar
crank is massaged.....being balanced.
...........now the only problem is........shall I supercharge it? or not ?
Old 03-24-2013, 02:49 PM   #89 (permalink)
LarryJ's Avatar
So what did you do differently to mount up the 03/04 tail than you did the first time around? The tail I bought from you sometime back. I'm curious because I don't see any welds on the braces. J subframe modded to accept the 636 fairing?
Old 03-24-2013, 04:39 PM   #90 (permalink)
badassjake's Avatar
nope, that's my race 2004 ZX10 tail. shortened stock subframe and secured.
