How to check if frame is bent? - KawiForums - Kawasaki Motorcycle Forums
post #1 of 13 (permalink) Old 12-30-2010, 04:15 PM Thread Starter
jjb
What is the best method for determining if the frame is bent? Also, how many of you would ride a bike that you wrecked again?
jjb is offline
post #2 of 13 (permalink) Old 12-30-2010, 04:21 PM
chuckbear's Avatar
I'm riding a bike I've wrecked twice. Got hit by a preggers chick once and low-sided at the track once. Long as everything is straight and strong it's all good.
Can't really give you much help in checking if a frame is straight as I wouldn't really know where to start...
chuckbear is offline
post #3 of 13 (permalink) Old 12-30-2010, 04:26 PM
JasonX7's Avatar
Just look at it? I would suspect a tweaked frame would make the whole entire bike look a little fuggered up and feel weird.
Originally Posted by matego View Post
Dont pick on him too much, he is from Canada. He does not know any better. Thats like expecting a McDonalds worker washed his hands after taking an explosive shit.
Originally Posted by Habsfan39 View Post
but remember boys no matter how hot a chick is there's always a guy out there that's sick of her shit lol.
Habs
JasonX7 is offline
post #4 of 13 (permalink) Old 12-30-2010, 04:54 PM
Jeff in Kentucky's Avatar
The best, most expensive way- have a frame expert check it and straighten whatever is needed. Racers often spend the extra cash to try to be as fast as possible after a crash.
The most common way- ride it with no hands to see if it rolls straight on a flat road, see if it feels like it corners normally for both left and right turns, check the tire wear- it is normal for the left side of the front tire to wear faster for countries where you drive on the right side of the road, because the center of the road is usually higher for rainwater runoff. Check to see if the chain sprockets are wearing the same amount on both sides.
Jeff in Kentucky is offline
post #5 of 13 (permalink) Old 12-30-2010, 05:24 PM
Steve Mcqueen Wannabe!
bRiT636's Avatar
what bike? Like Jeff said, there are frame specialist like G.M.D. Computrack - HOME. I have wrecked and still ride it - depends on the wreck and the the bike.
05 636 * K&N Air * SS Goodridge frt T-lines * Arata Rearsets * PCIII * Akro Slipon-micron headers* GPR V1 Damper * Michelin Pilot Ones* Elka Triple shock *Nissin calipers* Ohlins 20 mm forks* Keyless entry* what Bikes are about
bRiT636 is offline
post #6 of 13 (permalink) Old 12-30-2010, 06:48 PM
arron's Avatar
how hard was the wreck? did you drop it and crack the plastics or slide it down the road at 100mph??
arron is offline
post #7 of 13 (permalink) Old 12-30-2010, 07:16 PM Thread Starter
jjb
The bike is a 07 zzr600, and the wreck was a highside at around 35mph.
jjb is offline
post #8 of 13 (permalink) Old 12-31-2010, 01:20 PM
Try this. It will be fairly accurate.
Do It Yourself, Motorcycle Frame Check
Root2812 is offline
post #9 of 13 (permalink) Old 01-02-2011, 05:27 PM Thread Starter
jjb
Will a dent in the frame be a problem?
Uploaded with ImageShack.us
jjb is offline
post #10 of 13 (permalink) Old 01-02-2011, 05:33 PM
Insurance would total it based on the frame dent alone
Quick10 is offline
