removing front sprocket nut - KawiForums - Kawasaki Motorcycle Forums
post #1 of 34 (permalink) Old 05-03-2007, 06:36 AM Thread Starter
nrodgers76's Avatar
ok so i am trying to replace my stock sprocket with a new one thats one tooth down. and i can't get the nut off to remove the sprockets... am i missing some important info or what... it is counter clockwise to remove correct??? and is there any easy way to do it? please help thanks
nick
nrodgers76 is offline
post #2 of 34 (permalink) Old 05-03-2007, 07:27 AM
bennsb's Avatar
2 words: Impact Wrench.
bennsb is offline
post #3 of 34 (permalink) Old 05-03-2007, 12:38 PM
AcingTeam's Avatar
Send a message via AIM to AcingTeam Send a message via MSN to AcingTeam
[:+1]
AcingTeam is offline
post #4 of 34 (permalink) Old 05-03-2007, 01:19 PM
Candyman's Avatar
On my 250 the sprocket nut is reverse thread, I'm not sure if thats the case with the 6R, but might be worth a try.
Put the bike in gear (if you havnt already tried that), it'll give you some resistance when you heave on it.
Also, try a breaker bar.
Candyman is offline
post #5 of 34 (permalink) Old 05-03-2007, 01:48 PM
If you took the chain off put it back on then put the bike in gear and have a buddy hold the rear brake on. This is the way I have always taken front sprockets off every bike I have worked on.
wannabe is offline
post #6 of 34 (permalink) Old 05-03-2007, 02:20 PM
kevalent's Avatar
The sprocket is a standard righty-tighty/lefty-loosey setup so it's counter-clockwise to remove. I just swapped mine out this past Tuesday and it was a PITA to get the front loose. After flattening the lock washer I put the bike on a rear stand and wedged a shovel-handle between the rear wheel and swingarm to keep it from turning. Then I just hooked up an 18" breaker bar, put a foot on the foot-peg and free hand on the seat to keep the bike steady and just kept yanking on the bar in quick forceful pulls (like a human impact gun). After about 20 of these quick yanks it broke free and could be spun off by hand.
I concur that an impact wrench would make much easier/quicker work of it if you have one available.
kevalent is offline
post #7 of 34 (permalink) Old 05-03-2007, 02:28 PM
jbreit's Avatar
nope, you aren't missing anything...it sucks.
2x4 through the spokes and over the swingarm....I broke the handle on my shovel..[B)]
now that I have an impact, its a piece-o-cake.
jbreit is offline
post #8 of 34 (permalink) Old 05-03-2007, 07:04 PM
lionlvr's Avatar
I do it just like Kevelent except I use a 2x4 instead of a shovel handle for the same reason jbriet pointed out.
I use a breaker bar also but I slip a 4' pipe over the handle. The nut breaks loose with ease.
lionlvr is offline
post #9 of 34 (permalink) Old 05-03-2007, 07:20 PM
lionlvr's Avatar
Forgot to mention...I use 3/4" drive sockets and breaker bar for this particular job. I would suggest you use AT LEAST 1/2" drive to break the nut loose with leverage. 3/8" drive might shear off before breaking the nut loose with that much leverage being applied.
I don't know about you but my dad will punch me in the face the next time he witness's me using a 3/8 drive "anything of his" with a leverage bar.[:0]
lionlvr is offline
post #10 of 34 (permalink) Old 05-04-2007, 12:38 AM
gohmer's Avatar
Send a message via AIM to gohmer
that brings back memories...
gohmer is offline
