key gets stuck in the ignition - KawiForums - Kawasaki Motorcycle Forums
post #1 of 42 (permalink) Old 05-25-2010, 03:52 PM Thread Starter
gdawg's Avatar
This has been frustrating as it just occurred this weekend.
Riding, then it rained on me hard, probably coincidence, but now i can't get the key out of the ignition?
It turns to the right, but doesn't turn to the left. So I can be in the on position, then right in the off position, then I have a hard time getting it to further turn to the "lock" position.
"edit" finally been working it by just twisting and flicking, and got the key out. key is not bent, and I tried using my spare, and got the same result, stuck key for like 20 mins trying to twist until something luckily catches and i can turn it fully, then voila, i get my key back
i added wd 40 into the keyhole but that hasn't help. any advice? do I need to buy another key box thing?
i going to have to carry 2 keys so I can be sure to be able to access my gas tank. also don't like the theft possibility of not being able to lock the steering or retrieve my key.
gdawg is offline
post #2 of 42 (permalink) Old 05-25-2010, 06:04 PM
Send a message via AIM to Leonthefaded Send a message via MSN to Leonthefaded Send a message via Yahoo to Leonthefaded
Same thing happens to me it gets real old real fast
Leonthefaded is offline
post #3 of 42 (permalink) Old 05-25-2010, 06:21 PM
Me too $#@$
Fox219 is offline
post #4 of 42 (permalink) Old 05-25-2010, 06:31 PM
KillaCody's Avatar
Squirt some lock lube down in it. Has some special metal additives in it that keep any lock cylinder moving nice.
04 ZX6R / 04 ZX6RR
KillaCody is offline
post #5 of 42 (permalink) Old 05-25-2010, 06:33 PM
mad dum son
cyberdos's Avatar
Send a message via MSN to cyberdos
lock lube?
git a brian, moran.
-Kurosaki
cyberdos is offline
post #6 of 42 (permalink) Old 05-25-2010, 06:39 PM
ballin 03 636's Avatar
Take air in a can or hook up a air pistol to a compressor and shoot out the crap that's in there and maybe there are stuck cylinders it there that will loosen then lube it up and try agin.
"Studies show geniuses choose green"
ballin 03 636 is offline
post #7 of 42 (permalink) Old 05-25-2010, 06:40 PM
zx racer's Avatar
i had this problem and i squirt some WD 40 down inside the ignition, took my key and turn it left to right and she works like new now...
zx racer is offline
post #8 of 42 (permalink) Old 05-25-2010, 06:42 PM
KillaCody's Avatar
Originally Posted by cyberdos View Post
lock lube?
The best lubricants for lock mechanisms are powdered graphite and/or teflon based lubricants from which the carrier solvents evaporate and leave a dry teflon coating on the internal surfaces of the lock mechanism.
04 ZX6R / 04 ZX6RR
post #9 of 42 (permalink) Old 05-25-2010, 06:43 PM
KillaCody's Avatar
WD40 in this application may eventually collect enough dust and dirt to cause the lock mechanism to stick again.
04 ZX6R / 04 ZX6RR
post #10 of 42 (permalink) Old 05-25-2010, 06:45 PM
mad dum son
cyberdos's Avatar
Can you recommend any? I used to use dupont tephlon spray for my chains on my dirt bikes. I guess this is acceptable?
git a brian, moran.
-Kurosaki
cyberdos is offline
