cant get past 7500rpm help. - KawiForums - Kawasaki Motorcycle Forums
post #1 of 12 (permalink) Old 01-18-2013, 06:42 PM Thread Starter
hello everyone new guy here with an issue i got a 03 zx6r with yoshi exhaust, power commander, 14/41 sprockets. my issue is i cant keep up with cars on the road i feel like a grandma riding, at every gear i gotta shift at 7000 cause i soon as i get to 7500 i loose throttle drops to like 5500 and i gain throttle again until 7500 any suggestions?
newninrider is offline
post #2 of 12 (permalink) Old 01-18-2013, 09:47 PM
Did you recently replace your cam chain tensioner?
Currently own:
05 Z750S
Have owned:
01 Volusia
Wrider is offline
post #3 of 12 (permalink) Old 01-19-2013, 03:20 AM Thread Starter
honestly i would not be able to answer that cause i got the bike as is.
post #4 of 12 (permalink) Old 01-21-2013, 09:01 AM
I have same problems. 7500 rpm..
sysroot is offline
post #5 of 12 (permalink) Old 01-21-2013, 09:27 AM
Is the engine not revving above 7500 no matter how far you open the throttle?
You could try getting your throttle position sensor checked out with a multimeter...
Hope this helps.
Tunksy is offline
post #6 of 12 (permalink) Old 01-21-2013, 09:34 AM
old man roger's Avatar
Clogged or bad fuel pump?
old man roger is offline
post #7 of 12 (permalink) Old 01-21-2013, 10:00 AM
I changed fuel pump.
I checked coil harness , coils, plugs , gas , fuel pump..
But the problem continues
sysroot is offline
post #8 of 12 (permalink) Old 01-21-2013, 12:33 PM
cookiebug79's Avatar
Have you checked the power commander harness and connectors to the injectors?
cookiebug79 is offline
post #9 of 12 (permalink) Old 01-21-2013, 02:19 PM
I havent power comment my bike , I checked connectors to the injectors..
sysroot is offline
post #10 of 12 (permalink) Old 01-21-2013, 10:10 PM
Tricky ZX6R's Avatar
Re: cant get past 7500rpm help.
Have you checked the fuel lines make sure there not kinked or twisted.
Sent from my HTC One X using Motorcycle.com Free App
09 Kawasaki ZX-6R Monster Edition
DDM Tuning 35w/5k HID's, DDM white LED running lights,
HotBodies Tinted Wind Screen, Vortex Rear Spools,
T-Rex Racing Lowering Links, K&N Air Filter,
Modified Jardine GP1 Slip-on
Tricky ZX6R is offline
