Hello Guys,
I really need some advice on this one, my ignition lock is jammed. At first I thought it's the weather because it's cold it could've froze etc, pouring boiling water onto it fixed it before. However this time I think it's different, the key does not go all the way in - it stops 95% of the way in and of course I can't turn it because it isn't all the way in.
I have tried WD40, moving the bars and using a different key. Oh and what's worse is that it's in steering lock. What are my options? I can't unscrew the ignition switch because the screws are bolted in. I could drill but I can't get in there because it's an awkward angle. I don't think I can take the yoke off either because the steering lock won't let it come off.
What should I do?
Thank you in advance.
What should I do?
