2003 Rim specs - question - KawiForums - Kawasaki Motorcycle Forums
post #1 of 6 (permalink) Old 01-18-2018, 04:10 AM Thread Starter
Hi
I've bought a set of rims for my 2003 ZX6RR. They are stamped as follows:
Front
J17M/CXMT3.50 DOT with tyre 120/60 ZR17
Rear
J17M/CXMT4.50 DOT with tyre 160/60 ZR17
I presume the 3.50 & 4.50 is the rim width.
I think they're too small for my bike. The work shop manual for my bike says the wheels specs are:
Front - 120/65 ZR17
Rear - 180/55 ZR17
It doesn't tell me the rim width though.
Can anyone confirm whether the ones I've bought are too small for my bike or not?
Thanks
Doonks is offline
post #2 of 6 (permalink) Old 01-18-2018, 01:54 PM
jowek70's Avatar
Based on the info you provided; the front wheel is fine as 120/70/17 fits on 3.5 wide rims but 180 rear tires require a 5.5 wide rim so you'll need to source another rear. The chassis is designed around wheel/tire sizes so anything drastic (going to a 160 rear) may make the bike unpredictable.
jowek70 is offline
post #3 of 6 (permalink) Old 01-18-2018, 06:51 PM Thread Starter
Thanks. I've contacted the seller and he has agreed to accept my return of the rims. My bike is a Track Bike only, so I don't want anything but stability and confidence
Doonks is offline
post #4 of 6 (permalink) Old 01-19-2018, 09:30 AM
jowek70's Avatar
Good call; if you're not too obsessed with the 3 spoke design, the later zx6 wheels (07-12?) are much lighter and I'm guessing can be swapped over pretty easily. The rotor bolt patterns are the same (rear rotor is identical for all zx6). Worst case you have to swap wheel bearings to accommodate differing axle sizes, which is about $40 worth of parts and 20 minutes time.
jowek70 is offline
post #5 of 6 (permalink) Old 01-19-2018, 06:00 PM Thread Starter
Cheers. Not obsessed at all, it's a track bike. However, I want the 2nd rims to run wets so I don't have to miss a session due to a rain shower. What I want is to be able to take the rims with slicks off, and pop the wets straight on with a minimum of mucking around. I'll see if I can find out rim compatibility with bearings etc. It's heaps easier to find later model rims than it is 03/04, especially here in Australia
Doonks is offline
post #6 of 6 (permalink) Old 01-19-2018, 11:31 PM
jowek70's Avatar
Makes sense
You run captive spacers I assume?
Could luck out if axle sizes are the same between models
Any photos of the bike?
jowek70 is offline
