bike stalling out - KawiForums - Kawasaki Motorcycle Forums
post #1 of 9 (permalink) Old 06-21-2010, 12:31 PM Thread Starter
Justanothaguy's Avatar
bike stalling out
This happens every now and again.. seemed to happen alot more before i drove it around quite a bit.
every now and again if i just give the bike a little bit of throttle while in neutral and let off the throttle the bike will just stall out... it will also do it sometimes if im gearing down for a stop and pull the clutch in it the engine will rev down like normal but instead of holding at idle it will just stall out..
its not a super huge problem but is something im curious about. does not happen too often but often enough to be an annoyance
tired searching found no results.
its a 2009 zx6r.. it was properly broken in and has right at 1700 miles on it now.
Justanothaguy is offline
post #2 of 9 (permalink) Old 06-21-2010, 12:34 PM
Vandarel's Avatar
What is your idle set to ? If its to low this could be the issue. I keep mine about 1400 - 1500 rpm on idle.
2009 ZX6R All black like a real ninja. (STOLEN)
Current upgrades: Akrapovic Evo Slip-On + Link Pipe, Shogun Sliders , DDM 35w 6k HIDs , CustomLED Intergrated Taillight, LP Fender Eliminator.
Future Upgrades: SS brake lines, PCV.
Vandarel is offline
post #3 of 9 (permalink) Old 06-21-2010, 01:51 PM Thread Starter
well dont i feel dumb.. i just came off a carbed bike and did not realize i could so easily adjust the idle speed on a fuel injected bike.
thats the quickest and easiest fix ive come across.
thanks again. =]
post #4 of 9 (permalink) Old 06-28-2010, 03:57 PM
HyperUppercut's Avatar
i run into this problem sometimes too. how do you adjust the idle?
HyperUppercut is offline
post #5 of 9 (permalink) Old 06-28-2010, 04:10 PM
There's a knob attached to one of the coolant hoses on the left (clutch) side of the bike
2009 ZX6R
11.538 @ 124.90
MPA4LYFE is offline
post #6 of 9 (permalink) Old 06-28-2010, 04:20 PM
okay. Ima check it out when I get off work. So do you jus give it a couple twists and you are good?
post #7 of 9 (permalink) Old 06-28-2010, 04:30 PM
twists, no, partial turns yes.
just run the bike til it warms up and adjust it a little at a time. Should be right to raise the idle, left to lower IIRC
2009 ZX6R
11.538 @ 124.90
MPA4LYFE is offline
post #8 of 9 (permalink) Old 06-28-2010, 05:48 PM
srmoore35's Avatar
yea be gentle with it. Doesn't take much.
Hold my beer and watch this!
srmoore35 is offline
post #9 of 9 (permalink) Old 10-09-2019, 09:57 AM
I'm having the same issue on brand new stock 2018 zx6r. It doesn't matter gear and adjusting idol speed only seems to delay the issue for a little before it comes back. Dealerships and shops say they can't recreate or find a problem
Ninja-wolf-3 is offline
