Bazazz Zfi-Awesome! - KawiForums - Kawasaki Motorcycle Forums
post #1 of 14 (permalink) Old 07-14-2012, 10:33 AM Thread Starter
swami's Avatar
Wink Bazazz Zfi-Awesome!
hi all,
santa claus brought me a Zfi and i finally got around to getting it installed. my mechanic with 37 yrs professional experience did a killer job and it functions flawlessly on the slip-on map. i also upgraded to a K&N air filter and my first impression riding home was how much louder the yoshimura slipon and air intake sound was. the bike is much smoother throughout the rpm range and gone is the 12-16,500 powerband. i guess the factory had it leaned out from 0-12,000 for emissions? anyway, i'm very happy with the results as is but may get it dynoed or install the Afm package down the road. unless someone has a map they'd like to share? HTH
swami is offline
post #2 of 14 (permalink) Old 07-14-2012, 10:44 AM
agg2001's Avatar
bazzaz makes killer stuff.
but don't bother with a dyno tune. just get the afm add-on unit and have yourself an on-board dyno. i love mine. my bike has "gittup" that stock 750's notice. a perfectly tuned 600 is a beast compared to stock. that's for sure.
agg2001 is offline
post #3 of 14 (permalink) Old 07-14-2012, 11:24 AM
forcedvw's Avatar
Bazzaz AFM Questions
That is great to hear Swami. I was looking into the Bazzaz unit and their accessories myself.
I have researched the AFM as well. I am extremely curious to know how those who have an AFM are setting the correct settings without having a dyno. Bazzaz has a video on YouTube that shows how to allow the system to make suggestions at each TPS and RPM value. I don't see how you know that you are covering the spectrum if you don't have a Dyno handy and have the bike connected at the same time. Is it a process where you set a default map and then go out over and over and try to catch any cells that don't have recorded values or are you just taking data that you have and then smoothing it over to make nice transitions in your fuel delivery?
09 ZX6R - SOLD
Woodcraft Sliders, Spools, & Engine Protection Covers; Vortex Clip-ons, Bar Ends, & Rear Sets; Tech Spec Snake Skin; Spiegler SS Lines; K&N Filters; Puig Windscreen; Shorty Brake and Clutch Levers; Motion Pro Revolver; Diablo Supercorsa SC's;
forcedvw is offline
post #4 of 14 (permalink) Old 07-14-2012, 01:25 PM
agg2001's Avatar
i have one... i set my target a/f to 13.2 and ride. after each session on track, i check out the suggested changes to the map that will get me to the target a/f. if everything looks ok, i'll apply all. i ride through all rpm ranges, so that's how it tunes. it's not THAT complicated... you're overthinking it.
afm > dyno. hands down.
well, unless you LIKE spending ~$200 each time you want change/mod your bike (performance-wise).
agg2001 is offline
post #5 of 14 (permalink) Old 07-14-2012, 03:07 PM Thread Starter
swami's Avatar
the reason i choose bazazz over pcv was because when i emailed dynojet about why their unit only controls 4 injectors they CURTLY told me that was all was necessary unless you were running a power adder like turbo or nitrous. then, they came out with an addon module so you can control all 8 injectors but then they are way out of the game money wise. i was concerned because alot of people complain about no fuel alterations below 3000rpm but that is irrelevant. the only time i see below 3G is when i'm riding through the grass to park in my garage. i did have to increase the idle from 1100 to 1300 and i may use the software on my laptop to increase fuel 5% at a time from 0-3000 but it is mostly a moot point.
i use my bike to ride to work weather permitting 20 miles each way with about half twisties (look out deer!) and half interstate and i was astonished with the 6th gear acceleration above 70mph. all you have to do is barely move the throttle and look out speed limit. HTH
Bazazz Zfi
K&N air filter
Yoshimura RS-4 slip-on
swami is offline
post #6 of 14 (permalink) Old 07-14-2012, 08:19 PM
J_Fuggin_T's Avatar
i've got mine with a dynotune, perfect your more than welcome to the map if you'd like, its a stock header w/ a m4 slip on.. my tuner was able to get 115hp & 46ft lbs
Mod list: GP 25mm front cartridge kit / JRi piggyback triple shock / attack rear link / Brembo RCS / Galfer SBK lines / Leo Vince Factory Corsa R full exhaust/ BMC Race Filter / Yosh Case Savers / Vortex Clip ons / Vortex Rear sets / Vortex Keyless Gas Cap / Lighttech Chain adjusters /AIM solo DL data logger / motion pro throttle / KIT ecu & Harness / Hotbodies WSBK bodywork /
J_Fuggin_T is offline
post #7 of 14 (permalink) Old 07-14-2012, 08:38 PM
BlackDog's Avatar
way back, we had put the O2 sensor on the pipe and used the Auto-mapping with GREAT success!
Bazzaz Rules!
ID:	49922   Click image for larger version
BlackDog is offline
post #8 of 14 (permalink) Old 07-15-2012, 08:35 AM Thread Starter
swami's Avatar
now, that would be awesome! PM sent. TIA
Bazazz Zfi
K&N air filter
swami is offline
post #9 of 14 (permalink) Old 07-15-2012, 11:53 AM
J_Fuggin_T's Avatar
map sent buddy
post #10 of 14 (permalink) Old 07-15-2012, 12:29 PM Thread Starter
swami's Avatar
map sent buddy
you rock! will try it out. how did it compare to the bazazz slipon map?TIA
Bazazz Zfi
K&N air filter
swami is offline
