HELP! Can caliper seals cause piston drag? (pic) - KawiForums - Kawasaki Motorcycle Forums
post #1 of 23 (permalink) Old 04-04-2014, 05:47 PM Thread Starter
speedee911's Avatar
So I was changing my brake pads and the calipers were filthy and pistons weren't coming out at the same time. I went to clean them and I pumped the lever a bit too much and one of the pistons came out, so I decided to take them all out and clean the calipers really well with a toothbrush.
At this point I thought I'd try and reuse the seals and if it leaks I'd just go back and change them. Well they don't seem to be leaking, BUT, the pistons are just as bad as before, even though they're clean. On the right caliper only one piston is coming out on the first 3 lever pumps or so.
Would changing the seals solve this, or is this a problem with the pistons? The reason I need to know is because if its just the seals, I'd like to replace them. However if its the pistons, I'd rather upgrade to Brembo calipers than spend $300 rebuilding these ones.
This is a pic of a piston that is "stuck" or comes out much later.. Looks pretty clean
speedee911 is offline
post #2 of 23 (permalink) Old 04-04-2014, 07:45 PM
It definitely wouldn't hurt to replace them. Probably not much trouble, but the one that's coming out before the rest stands a good chance of its seal leaking first.
Currently own:
05 Z750S
Have owned:
01 Volusia
Wrider is offline
post #3 of 23 (permalink) Old 04-04-2014, 08:12 PM Thread Starter
speedee911's Avatar
Ah ok, I've been looking at it the wrong way lol. I was thinking "the ones that aren't coming out are the problem and they're somehow stuck", when I guess it's "the one that comes out easily probably has the seals worn"... Thanks!
post #4 of 23 (permalink) Old 04-06-2014, 07:26 PM
Duc995's Avatar
I don't think that there is necessarily anything wrong just because the caliper pistons - while off the disc - come out at different rates when you pump the lever. There has got to be somewhat of a pressure differential inside of the caliper even though the brake fluid is essentially "incompressible." Are the diameters of all the pistons identical - I don't know - but it would affect their rate of protrusion as well. I'm thinking you are maybe seeing a "problem" that might not really exist.
Duc995 is offline
post #5 of 23 (permalink) Old 04-07-2014, 09:38 PM
WCCoffey's Avatar
Send a message via AIM to WCCoffey
There is nothing wrong. That is normal operation. Thats just what it does. when you add the resistance of the pads the pressure is more even.
If you replace it. The replacements will do the same.
Chris Coffey CMRA Racer #907
2014 Sponsors
Johnson Equipment Co - Norwood Auto Italia - Woodcraft CFM - Nexx Helmets - SouthCentralRaceCenter - Pirelli Tires - Racer Gloves USA
WCCoffey is offline
post #6 of 23 (permalink) Old 04-12-2014, 12:16 PM Thread Starter
speedee911's Avatar
Thanks for the info.
What really got me worrying is that I changed the brake pads and bled the brakes right before a track day. And then I was having trouble with the brakes the whole day before I crashed by riding on the curb (learned the hard way you can't do that lol). At first I thought it was the new pads, but after 2-3 sessions they should've bedded in. So I guess it is my bleeding that's the problem. Gotta buy a mighty vac or something
post #7 of 23 (permalink) Old 04-12-2014, 05:55 PM
Duc995's Avatar
What specifically was the problem with the brakes during the actual track day?
Duc995 is offline
post #8 of 23 (permalink) Old 04-15-2014, 04:45 AM Thread Starter
speedee911's Avatar
Just not enough stopping power. I had to get on the brakes way early so I would stop in time.
post #9 of 23 (permalink) Old 04-15-2014, 10:35 AM
Duc995's Avatar
I have the same problem with my '12 so I am experimenting with different brake pads. Also, it has been recommended to me to prep the rotors by sanding and re-cleaning their surfaces to get the pads to feel like new again.
Duc995 is offline
post #10 of 23 (permalink) Old 04-16-2014, 11:08 PM
WCCoffey's Avatar
Stock brakes should work very well.. I raced on stock pads w/ braided lines at a very heavy braking track and had no issues.
2014 Sponsors
WCCoffey is offline
