zx6r new chain whining noise - KawiForums - Kawasaki Motorcycle Forums
post #1 of 9 (permalink) Old 04-28-2012, 06:02 AM Thread Starter
my chain is making a whining noise after i installed a new chain i don't know if its the solid soft nose master link, the chain came with a clip master link so they ordered me the rivet one (at no cost) but now its makes a whining noise as around 60 to 70 kms or when I pull the the clutch in (when slowing down) can any one help p.s. the chain /wheel is alined
pninja is offline
post #2 of 9 (permalink) Old 04-28-2012, 07:53 AM
SDub518's Avatar
Did you lube it?
07 ZX6R I ride a NINJA, FUCK WHAT YOU THINK!
Supercheese88- You can't find anyone that wants to get in on a sibling 3 way? Weird.
Originally Posted by iVintage87 View Post
Never stick your dick in crazy!
SDub518 is offline
post #3 of 9 (permalink) Old 04-28-2012, 11:28 AM
04RDA's Avatar
Correct chain tension?
04RDA is offline
post #4 of 9 (permalink) Old 04-28-2012, 12:12 PM
BlackDog's Avatar
if you only changed your chain, it could be worn sprockets not matching the new chain...
BlackDog is offline
post #5 of 9 (permalink) Old 04-28-2012, 12:37 PM
ZX6RRNewbie's Avatar
What they ^^ said plus check your rear wheel alignment.
Sent from my Motorcycle iPhone app
from BEAUTIFUL AUSTIN TEXAS
2006 Lime Green ZX6R
ZX6RRNewbie is offline
post #6 of 9 (permalink) Old 04-28-2012, 09:41 PM
Powerhungry
nevada's Avatar
did you replace the front sprocket?
most aftemarket sprockets dont have the rubber cushion like the OE has. and they whine, and make a lot more noise.
and i 2nd the correct adjustment. if its too tight, it will whine too.
ERIN
nevada is offline
post #7 of 9 (permalink) Old 04-28-2012, 09:58 PM Thread Starter
thanks for all the advice the sprockets are fine its well and truly lubed might take to shop tomorrow see what they say
pninja is offline
post #8 of 9 (permalink) Old 05-01-2012, 05:37 AM Thread Starter
problem fixed turned out to be 2 problems one was over tightened solid nose master link, and the other seemed to be the axle nut wasn't torqued enough and was maybe throwing the alignment out, any way its fixed.
pninja is offline
post #9 of 9 (permalink) Old 05-01-2012, 12:39 PM
Digital Calipers ($10 at Harbor Freight) come in very handy when measuring how much to crimp the master link.
Lose Axle Nut? That's why you need a 1/2" torque wrench!! Very cheap at Harbor Freight too!
