How To: 07/08 Gauge Color Change - Page 12 - KawiForums - Kawasaki Motorcycle Forums
post #111 of 137 (permalink) Old 10-13-2008, 04:35 PM
rpc07's Avatar
I just ordered the led's i'll see if i have the balls when they arrive
rpc07 is offline
post #112 of 137 (permalink) Old 10-19-2008, 07:35 PM
Send a message via AIM to BLUE08ZX6-R
Just finished mine
BLUE08ZX6-R is offline
post #113 of 137 (permalink) Old 10-19-2008, 10:00 PM
rpc07's Avatar
Originally Posted by BLUE08ZX6-R View Post
Just finished mine
Loooks sick man, I was going to attempt this until i got the led's in the mail and so how damn small they are. in the pics they look much bigger. can anyone post a link of what type os soldering iron they used must have had a very tiny tip.
Thanks, Ryan
rpc07 is offline
post #114 of 137 (permalink) Old 10-20-2008, 06:45 AM
Thanks, Ryan
Thanks, This was actually very easy for me, I'm an electronics technician so I'm used to soldering IC's and SMD even smaller than this.
I use a Tenma adjustable soldering station with a fine tip. The right tools definitely help, but alot of experience with soldering is a must.
I thought about doing these for other people but it'd be too much of a hassle with shipping back and forth.
post #115 of 137 (permalink) Old 10-21-2008, 06:17 PM
silverbullet2005's Avatar
Just finished mine
Looks good, is the bike running? if not then it looks like your needle is off a tiny bit from the 0 mark.
08' ZX-10R Lime Green
T-REX Spools & Sliders, Harris Tank Pad, CFL Gas Cap Pad, ProGrip 724 Grips, Kawasaki Seat Cowl, HM Fender Eliminator, "Pure Green" LED, gauges, StarRotors HID's, ASV C5 shorty levers, Buell XB Footpegs
silverbullet2005 is offline
post #116 of 137 (permalink) Old 01-04-2009, 01:18 PM
RMSZX6R's Avatar
Ive done 3 green with white tach. and still have plenty of green and white led's left if anyone close wants it done I can help.
Jumper mod, pc, custom can, ultra bright green/white gauges, polished rims, rear brake res relocated, fender elem, vs smoke signals, de-decaled, LED nose light, engraved bar ends,and kietti tankpad,
RMSZX6R is offline
post #117 of 137 (permalink) Old 02-23-2009, 11:41 PM
antiseptic011's Avatar
Thumbs up Finished!
To begin with, thanks for the write-up tycar86r. I found this write-up first on www.i-hacked.com but it was for a gsxr cluster so i was lost. I had actually planned on making mine all blue but after burning a few I ran out, so I improvised and used some white ones that I had. So now it looks like the blue fades to white and then back to blue. If you decide to do this mod, I would recomend that you play with different colors before you set on one color scheme. (If you have the nerves)
antiseptic011 is offline
post #118 of 137 (permalink) Old 03-19-2009, 12:32 PM
I went with blue. It looks great. Thanks for the tips.
morbidangels is offline
post #119 of 137 (permalink) Old 04-13-2010, 09:00 PM
07BLKNINJA's Avatar
Location: North Versaille, Pennsylvania, United States.
Send a message via AIM to 07BLKNINJA
whats up guys. i just did mine. and no go lol. led 1 and 2 will not light for the life of me. and the 2 for the gear indicator. but other then that they look sick.. SO my "?" is what do i need to do to fix this. i contemplated making jumper wires from a power source to the 4 LEDs that r out and jumper grounds. but i didnt know if it was 12v going to the LED or not or what i can do.
2oo7 ZX-6R All Black, Chrome wind screen, Pilot Powers, Yoshimura RS-5 Full Exhaust, PCIII, SS fender Eliminator, Relocated Rear Brake Res., 6000k H.I.D., Green CCFL Angle Eyes, Jumper Mod, Race Railz, Sun Star Front And Rear Sprockets 15/46 Green Drive Chain,
"It ain't Your F&*k'n Leg Don't Worry About It" "Lay-It Low"
07BLKNINJA is offline
post #120 of 137 (permalink) Old 04-15-2010, 02:07 PM
07BLKNINJA's Avatar
Well I brought my volt meter home lastnight and ohmed out the leds and everything was turning up normal. But the one led had 8volts to it. So I removed the 4 that were not working. And soldered in 4 new ones and everything worked. Idk if there wired in seriese or what but once I put them all on the bored everything works great came out perfect
