How To - Winterize - KawiForums - Kawasaki Motorcycle Forums
post #1 of 24 (permalink) Old 12-06-2010, 10:09 PM Thread Starter
VeX
I ♥ Cute Cats!
VeX's Avatar
Lightbulb How To - Winterize
I hate to always be the one to make these threads... But oh well. There are threads in EVERY SINGLE motorcycle specific forum about winterizing motorcycles and guess what? The process is damn near identical for ALL motorcycles.
In fact if you have one of those new-fangled internal combustion engines I'd bet the process on ANY ONE OF THEM is similar. So let me begin:
Gasoline: This one's a biggie! Leaving gas sit for a long period of time is no good.
1) Fill the tank as full as you can. The more the space inside of a tank for air to circulate, the more water can be absorbed into fuel (which is what causes gumming!) The most important thing you can do is fill your tank to the brim with 87 octane (AKI) fuel. Check your particular country, but most countries don't use ethanol in the lowest grade of fuel and ethanol is used often times to raise octane. Since ethanol is very hygroscopic (it absorbs water) running a full tank of 87 octane usually sees the lowest ethanol content.
2) There are several different schools of thought on which additive to add to a fuel tank for winterizing. You'll get never ending debates on this one so I'll just present the 3:
a) Sta-bil. Stabil is a fuel stabilizer. It prevents your fuel from breaking down, minimizes water absorbsion, etc. It's been around forever, so there's got to be something to it. Additionally Sta-bil Marine Formula is stronger and is geared towards preventing water absorbsion. It's very good if you aren't sure of your ethanol content in fuel.
b) Heet. Heet is a "fuel anti-freeze". It works very well at absorbing water and if you're simply going to drain your fuel after Winter (like you should) then using Sta-bil to reduce the fuel from losing octane over Winter is kind of fruitless if you're going to just drain the tank in the Spring. Heet is magical stuff.
c) Seafoam. Why yes, the magical fuel system cleaner that people swear by is also what people also use as their fuel treatment of choice for Winterizing. Adding adequate quantities of Seafoam to a full fuel tank is a legit option.
3) Run the engine! Why not do a quick jaunt around town for 10 miles to ensure the treated fuel has completely circulated through your fuel system? Simply filling your tank and adding a fuel treatment isn't going to magically cause it to traverse your fuel lines, fuel pump, fuel injectors/carburetors, fuel rails, etc. You need to get that stuff through everything.
Check your antifreeze: If you're in a cold climate you probably have or have access to an anti-freeze tester. They're inexpensive and simply measure the specific gravity of your coolant.
If you have a track bike which is going to be subjected to sub-freezing temps you'll probably have to drain your coolant and add an anti-freeze/water mix. If you have a street bike you likely may only have to drain some coolant out and add pure anti-freeze to raise the anti-freeze content of your coolant. If you live somewhere where the temps only get down to perhaps the teens then getting your coolant down to perhaps 0 degrees Fahrenheit stable doesn't take much more than 30% anti-freeze content. If you're somewhere where it might dip down to -30 degrees Fahrenheit then you'll likely need a 50/50 mix of anti-freeze and water.
Note: By water I mean distilled water. Not purified water, not tap water, not ionized water, etc. but DISTILLED water. They sell it at every grocery store. Buy a gallon or two, toss it in your garage and use as needed. I literally have a gallon or two of distilled water in the garage at all times as it doesn't go bad and is safe insurance against corrosion.
Oil: Drain the oil out of the bike and refill with fresh oil. Nothing fancy! Just cheap oil. Come Spring-time you'll dump that and refill with your oil of choice. During long sits oil absorbs water and becomes acidic so you're just using the oil for that purpose over the Winter.
SOME people also go the added distance, pull all the spark plugs out, and with a turkey baster pour a small amount of oil in each cylinder (like 20cc's), and crank the engine a few times (to get oil on the cylinder walls and rings), and then put the plugs back in loosely to prevent anything from finding its way into the cylinders. This is preferred, but some people go crazy with the oil and that can cause more problems. I personally don't bother (shame on me I know) because most modern motorcycle engines have aluminum head(s), aluminum pistons, and Nikasil coated cylinder walls. The only thing that could potentially be problematic are the steel piston rings. But then again they are often plated and don't corrode like piston rings of yesteryear. Then the secondary rings really wont see enough air to be affected.
Battery: You can't leave the battery plugged in and expect it to not only still HAVE a charge at Winter's end, but to have not have permanently damaged the plates inside the battery. There are a few ways to take care of this:
Good: Unplug the battery.
Better: Unplug the battery and hook it up to a battery charger every month to top it off.
Best: Unplug the battery and hook it up to a battery tender and forget about it until the end of Winter. It will remain fully charged and the periodic charging will keep it in "like new condition". Battery Tenders are less than $30 and literally will pay themselves off after ONE Winter season.
Tires: Leaving hundreds of pounds of weight on a tire for a long period of time will cause the rubber to fatigue there and cause a tire imbalance. You can't leave a car/truck/motorcycle sit for long periods of time without hurting the tires.
Good: Air up the tires to their max to prevent them from flat-spotting.
Better: Swap the wheels/tires for a set you don't care about.
Best: Put the bike on stands! For usually less than $150 you can get a quality set of stands to prop the front and rear of a motorcycle up to prevent the tires from rutting. Putting a bike on stands takes less than 5 minutes and is all the preventative maintenance you need to do for the tires for storage.
Note: Picture is of KF member FarmerSTI's ZX6r. It's a good example of a bike on stands
Cover. I prefer to stuff something into the muffler to eliminate moisture, air, rodents, etc. from getting in. Toss something like a bike cover over the whole bike, and you're done.
If there's anything I've forgotten or you have some tips or tricks, drop a comment. No one is ever content so I anticipate people chiming in that I'm a dickfore and they do everything completely differently and have had wonderful results over the past 50 years or so with their methods. Oh well.
VeX is offline
post #2 of 24 (permalink) Old 12-07-2010, 05:20 PM
Tronix102's Avatar
Please sticky this so I dont forget and post something stupid :P
2012 Triumph Street Triple R - My youtube channel with my videos
Tronix102 is offline
post #3 of 24 (permalink) Old 12-07-2010, 05:39 PM
hedz0r's Avatar
vex... what would KF be with out you.
Everyone should believe in something, I believe I'll have another BEER.
hedz0r is offline
post #4 of 24 (permalink) Old 12-07-2010, 06:52 PM Thread Starter
VeX
I ♥ Cute Cats!
VeX's Avatar
LOL Well I was going to go through and link everyone in the current run of Winterization threads to a thread in the DIY forum, but alas there were none! Sooo yeah. Hooray beer!
VeX is offline
post #5 of 24 (permalink) Old 12-07-2010, 07:20 PM
Strat - the Asian edition
bubbleboys's Avatar
once again you've done it vex
now if only newbs would run a search and find this
Originally Posted by katina View Post
Well it's better than banging every shmuck who does so much as smile at me. I'm not that desperate.
Yet.
"oh herro your honorbrel honor. I no speed on your highray."
bubbleboys is offline
post #6 of 24 (permalink) Old 12-07-2010, 07:46 PM
Penthos's Avatar
Good stuff...put it as a sticky on top of every section.
'09 ZX6R Kawi green. miles: 28,861 so far. Mods: M4 GP slip-on, Spiegler SS brake lines f/r, Carbon Lorraine brake pads (f) XBK5 (r) RX3, LSL frame sliders, CRG rC levers brake/clutch, Ohlins steering damper upgrade by LAKO Performance Group, Pitbull spools, StompGrips, SATO Racing rearsets - oil cap - race hooks, Zero Gravity Corsa smoked windscreen, Kawasaki Solo Seat Cowl & custom fender eliminator.
Penthos is offline
post #7 of 24 (permalink) Old 12-07-2010, 09:01 PM
whitehendrix's Avatar
AND.. linked in mah how-to nav.
►Sept09 B.O.T.M. winner◄
Need A "How To"? CLICK ME!!
whitehendrix is offline
post #8 of 24 (permalink) Old 05-21-2011, 03:12 AM
resiak's Avatar
Seems easy enough... Thanks for the write up! I was wondering what I was going to do with my bike in the winter. I have a couple of those portable shelter type deals that I can keep it in.
Do you think it's worth it to pay a bike shop to store your bike over the winter? I was told I could have my bike stored in a heated garage for $300 and they change oils, clean it up, etc. (not that I don't clean my bike obsessively anyways
resiak is offline
post #9 of 24 (permalink) Old 12-09-2011, 10:44 PM
krazyk86cu's Avatar
Sorry to bring up the dead, but do I need to "winterize" my bike if it's going to sit in a heated hallway of an apartment for a month max? Can I just fill up the tank, and hook the battery up to my tender and be good to go?
krazyk86cu is offline
post #10 of 24 (permalink) Old 12-12-2011, 09:04 PM
Jeff in Kentucky's Avatar
You might be fine with your plan, but it would be better to stabilize the gas with one of the methods listed in the first post. It is also best to get the tires off the ground, or roll the bike a few inches every 2 weeks to prevent flat spots in the tires.
Do not start the bike and let it idle for a few minutes then shut it off. It is best to never start the engine unless you are going to ride the bike several miles, preferably with at least 5 miles at 60 mph plus.
Running the engine longer and above idle gets the engine hot enough to evaporate water out of the engine, and it gets acids out of the bearings and into the oil and into the oil filter. Oil comes with acid neutralizers in it, but the oil has to be mixed enough for the neutralizers to come in contact with the acids in the oil.
Most of the time the rings or valves fail before the bearings get worn, but if an engine does throw a rod, it may have been because of too much bearing wear, possibly from acids in the oil. Synthetic oil greatly reduces acid formation, along with changing the oil so it is new before storage.
Jeff in Kentucky is offline
