How To: 03-06 636 gauges on a G and J model 600 - Page 4 - KawiForums - Kawasaki Motorcycle Forums
post #31 of 49 (permalink) Old 10-18-2009, 03:27 AM
MasterMech77's Avatar
Great Mod... Killer looking too!
CAGERS BEWARE
MasterMech77 is offline
post #32 of 49 (permalink) Old 02-27-2010, 03:25 PM
turbophein's Avatar
can't seem to get the fuel light to shut off on my 05 speedo. i tried adding power from the red/blue stripe wire and nothing, i tried ground and direct power straight to the pin but still nothing.
i know the 03-04 gauges you can't bypass, but i thought the 05-06 you could bypass. anyone?
99 ninja zx6r work in progress.---06 zx636 forks, triples, clip ons, brakes, 05 zx636 speedo, 06 zx636 Swingarm & Shock, 06 zx636 Rear Wheel Complete, 06 zx-10 Rear Caliper and line. Yoshi Slip-On-Cut Down...
Here's the project link! https://www.kawiforums.com/showthread.php?t=111437
turbophein is offline
post #33 of 49 (permalink) Old 03-04-2010, 06:40 AM
I THINK that if you add an inline resistor or 25 Ohms or more, it will turn the list off. According to the service manual anything less than 22 Ohms turns the light on.
I'm also working on a mod that should let the 98-02 temp sensor work, but be up to 12.5% out.
mikezs is offline
post #34 of 49 (permalink) Old 05-29-2010, 11:34 PM
u531355's Avatar
has anyone posted up the wiring side of the install for the 98-99 models. if not i'll post up how to wire it up
u531355 is offline
post #35 of 49 (permalink) Old 08-25-2010, 04:17 PM
i bought the 05-06 speedo.. and i already have the speedohealer, anyone know what i should set the speedohealer on? i run now with 15-43 gearing. and adjusted the healer to this gearing... think it was -11,8...
and someone figured out the fuel warning lamp? how to bypass it so it wont flash all the time?..
Mats
Lundis-85 is offline
post #36 of 49 (permalink) Old 09-24-2011, 11:19 PM
shift light
Does this the shiffter ligths will work whe the swap is complete?
Danny-Z is offline
post #37 of 49 (permalink) Old 10-11-2011, 05:15 PM
Originally Posted by bennsb View Post
I'm 99.9% sure it will. The front sprocket has 12 spots for the pick up sensor to read vs. 6(?) on the pre 2005's(which is why the 03-04 gauges speed is compatible). Not absolutely sure, but I'll check.
If I find a cheap 07 cluster, I'll let everyone know if it is the same to setup.
Do you know how wide is the water sensor temp in ZX6R 02 vs 03? I'll try to make the cluster 05 work...
Danny-Z is offline
post #38 of 49 (permalink) Old 08-11-2012, 12:43 AM
The remedy to 03-06 fuel level light on is install a 18K Ohms resistance ground to slot 2 in the connector!
Good luck everyone!
Danny-Z is offline
post #39 of 49 (permalink) Old 03-28-2013, 09:58 PM
I got the temp sensor working for this mod but it costed me $180 to get this done. The adapter was made at a local machine shop and thats the only way i found to make this work.
M1k3y2004 is offline
post #40 of 49 (permalink) Old 03-28-2013, 10:00 PM
I belive the shift light does work.
