Factory Pro Shift kit- 05/06 zx6r - Page 4 - KawiForums - Kawasaki Motorcycle Forums
post #31 of 38 (permalink) Old 10-09-2010, 03:30 PM
user8382's Avatar
Originally Posted by Johnny R View Post
The kawi clutch holding tool listed in the manual works great. A little pricey but much better than the $20 tool at cycle gear. I took that one back cause clamp part was too thick and would not fit in the hub teeth. I didn't want to spend the money on the tool but I already had it apart and wanted to do it right.
Just let the kawi tool arm rest on the footpeg and nut comes right off. Then have someone hold it underneath the footpeg when you tighten it back down.
I removed (Just) the pressure plate and clamped/ put pressure on the friction plates with my fingers. Then used an electric impact gun and the nut came right off! Same during installation Easy!
The Need for Speed Driven to Modify; Driven to Ride Modified!
user8382 is offline
post #32 of 38 (permalink) Old 10-10-2010, 05:03 AM
whitehendrix's Avatar
the surface tension of the oil across the plates will keep the clutch "applied" for long enough to zap the hub nut loose.
►Sept09 B.O.T.M. winner◄
Need A "How To"? CLICK ME!!
whitehendrix is offline
post #33 of 38 (permalink) Old 01-18-2011, 05:30 PM
DROCK's Avatar
Is there a part # for the kawi clutch holding tool?
DROCK is offline
post #34 of 38 (permalink) Old 03-23-2011, 10:09 AM
RawMuscle636's Avatar
Send a message via AIM to RawMuscle636
Beware of the Motion Pro tool from Motorcycle Superstore. It did not work at all for me, what a waste of 30$.
2006 ZX-6R: Full Yoshi Pipe, PCIII, DDM Hid lights, HyperPro RSC Damper, Factory Pro Shift Kit.
RawMuscle636 is offline
post #35 of 38 (permalink) Old 03-23-2011, 01:25 PM
DROCK's Avatar
Thanks for the headsup.
So, what does work?? anyone??
DROCK is offline
post #36 of 38 (permalink) Old 03-23-2011, 02:22 PM
chuckbear's Avatar
Read up a few posts.
The kawi tool works great.
chuckbear is offline
post #37 of 38 (permalink) Old 04-24-2017, 05:05 PM
Necrothread for sure, but does anyone know how I can tell if my OEM detent arm is steel or ceramic bearing? The guide here states it's ceramic from the factory, but Factory Pro states the OEM is steel. Not sure if there's any reason to replace it or not. Thoughts?
lolibater is offline
post #38 of 38 (permalink) Old 04-24-2017, 05:33 PM
Cancel that. Just got clarification from FP themselves. The mention of the OEM being "updated" was that they updated to a roller bearing (steel) from the friction pin/washer type on the 04-. FP claims the steel rollers on the OEM detent arm of the 05/06 is very good quality from what they've seen, and do not recommend replacing it unless you use a quick shifter, which I do not. Ordered the star kit on Amazon for $129 to the door. Here's to not false neutral'ing on the hairpin at Thunderhill anymore!
