cylinde head question. - KawiForums - Kawasaki Motorcycle Forums
post #1 of 8 (permalink) Old 07-28-2014, 04:38 PM Thread Starter
Does anyone know what the small hole under the plug is? Its located on the left side of the cylinder head, under the plug. This is on a 98 zx6r g1. Thanks in advance.
zxgr is offline
post #2 of 8 (permalink) Old 07-28-2014, 05:26 PM
Sev
The Indifference Engine
Sev's Avatar
Likely a drain hole in case water gets in around the sparkplug. Also serves to let the air escape as it heats.
Sev is offline
post #3 of 8 (permalink) Old 07-28-2014, 06:13 PM Thread Starter
The reason i ask is because starting a couple days ago is seeps oil out. Not vey much and only when it gets hot or riden hard.
zxgr is offline
post #4 of 8 (permalink) Old 07-28-2014, 07:59 PM
Sev
Sev's Avatar
Might be that the cylinder head gasket is starting to fail then.
Sev is offline
post #5 of 8 (permalink) Old 07-29-2014, 01:28 AM Thread Starter
Thats what i was afraid of. Well thanks for your help.
zxgr is offline
post #6 of 8 (permalink) Old 07-29-2014, 12:55 PM
panthercity's Avatar
I'd go through and re-torque all the cylinder-head bolts/nuts before I committed to a full tear down.
panthercity is offline
post #7 of 8 (permalink) Old 07-29-2014, 12:59 PM
Mad Hatter
alex2002zx6r's Avatar
I had this happen, and it turned out that i screwed up the o rings that go on the valve cover letting oil leak into the spark plugs and leaking through a little hole that looked pretty much dedicated to that.
08 gsxr 600-beater
Ford Exploder Zombie Response Vehicle
#zombieresponseteam @ IG
alex2002zx6r is offline
post #8 of 8 (permalink) Old 07-29-2014, 11:35 PM Thread Starter
Thanks for the help guys. It dawned on me today. I dont think its the head gasket. The oil and coolant look good. I believe alex is on the right track. I just did the valve cover gasket, however i didnt do the little orings under the valve cover that seal the plug holes. I thought they looked good,however i was probably wrong and they are seeping a little. In which that hole is venting the oil. Back in i go lol
zxgr is offline
You may post new threads
