New to Forum - gearbox question. - KawiForums - Kawasaki Motorcycle Forums
 1Likes
  • 1 Post By Jeffrey Raymer
post #1 of 7 (permalink) Old 05-22-2018, 07:06 PM Thread Starter
Jeffrey Raymer's Avatar
Hi everybody. New here. Used to ride a Aprilia 450RXv, down-graded to a DRZ 400 and now also have a 2007 Ninja 650R. Just searching out the 'clunky' gearbox issue. The bike shifts better when it's spooled up so shifting at higher RPMs is a must. But driving around town can get really annoying. I'm wondering whether oil weight has anything to do with it. A heavier oil might stick to the gears a little better and absorb some of the clunk. Or would a lighter oil flow better onto the gears once the clutch is pulled. Any thoughts?
Cheers
Jeffrey Raymer is offline
post #2 of 7 (permalink) Old 05-22-2018, 08:04 PM
WildCard's Avatar
No experience with the 650 myself, but I do know when I switched to Rotella 15w-40 in my Ninja the shifting seemed alot smoother, though it was never what I would describe as "clunky" on my bike.
It's worth a shot to try a little heavier oil, as long as your bike can use it.
damned. " - WillBrink
WildCard is offline
post #3 of 7 (permalink) Old 05-23-2018, 12:42 PM Thread Starter
Thanks. I always use Rotella as it has the highest JASO rating for wet-clutches. I haven't seen the schematics of the insides. Can Kawasaki oil pumps handle heavier weights?
post #4 of 7 (permalink) Old 05-23-2018, 02:21 PM
WildCard's Avatar
What oil are you using now ? If you are already using Rotella ?w-40 I don't think you will see any advantange to going to something else and a ?w-50 will likely be too viscous.
WildCard is offline
post #5 of 7 (permalink) Old 05-23-2018, 04:25 PM Thread Starter
5-40 as I've been running it on the road since late February.
post #6 of 7 (permalink) Old 05-23-2018, 05:10 PM
WildCard's Avatar
Check the owners/service manual and see if you can put a 50 in there I guess. For some reason my owners manual shows up to 20w-50 for my bike but the service manual only shows 10w-40 for my year.
WildCard is offline
post #7 of 7 (permalink) Old 05-25-2018, 01:50 PM Thread Starter
I dropped the oil and put some slightly lighter 15-W30 in to see if it makes a difference. None detected although the clutch seems a little more stable in neutral and doesn't seem to grab at all. Also a little quieter at higher RPMs and idling nicely. Bike has 20K miles on it so it's likely just worn gears. The temperature is high (30C) right now so I may drop and put some 20-W50 in and see how it shifts.
Cheers
WildCard likes this.
You may post new threads
