Gas leaking from fairing bolt?! - Page 2 - KawiForums - Kawasaki Motorcycle Forums
post #11 of 15 (permalink) Old 08-27-2008, 01:58 PM
IlBLisSlI's Avatar
Send a message via AIM to IlBLisSlI Send a message via Yahoo to IlBLisSlI
hmmm i kinda like the flat black look on the pre-08 250's
if i ever repaint i may go that route.
build a man a fire and he's warm for a day. light a man on fire and he's warm for the rest of his life.
https://www.kawiforums.com/showthread.php?t=119829
search tools, just use them.
IlBLisSlI is offline
post #12 of 15 (permalink) Old 08-27-2008, 02:01 PM
MODERATOR
hoser's Avatar
somebody probably used the wrong screw, too long. could happen to the first gen zx10's also, if you mixed up the fairing screws you ended up with a hole in the tank.
hoser is offline
post #13 of 15 (permalink) Old 08-27-2008, 04:46 PM
zeroth's Avatar
Knox,
I have the exact same problem with my '05 Ninja 250. It had been "worked on" by the previous owner, and apparently they'd punctured the gas tank. The bolt had copious amounts of silicone sealant on it, and now that I've loosened it, fuel oozes out. I haven't had time to drain the fuel yet though -- plan on doing it soon. Need to pick up a gas can and a vacuum pump (or a brake kit, like they mentioned in the Ninja250 FAQ article) first. I might just use JBWeld like someone mentioned, because I'd rather not replace the tank. My tank also has a couple of dents in it. If you're looking for a replacement tank, let me know how your search goes, how much they run etc. I might do the same.
Any other sealants that would work against gasoline?
zeroth is offline
post #14 of 15 (permalink) Old 09-01-2018, 11:40 AM
i have a 98 ninja 250 and the same problem i pull the top fairing/tank screws gas pours out it like that on both sides
bbwolf is offline
post #15 of 15 (permalink) Old 12-28-2018, 11:11 AM
bigbadbass's Avatar
Uncle Kawasaki really screwed up the engineering design of this fairing to tank hardware configuration.
'95 Ducati 900SS/SP
'07 Ducati SS800
'98 Honda VFR800 FI
bigbadbass is offline
