Handlebar ends/caps removal? - KawiForums - Kawasaki Motorcycle Forums
post #1 of 12 (permalink) Old 06-18-2009, 10:30 PM Thread Starter
Crazy tight, is there some trick to getting them loose?
theprocess is offline
post #2 of 12 (permalink) Old 06-18-2009, 10:43 PM
for some reason the factory uses red locktite on them - if you heat the ends up carfully with a torch or heat gun, that will help to loosen it, but be careful not to melt the grips You can also try an impact wrench - the manual kind that you hit with a hammer - they cost like $10, but be careful not to strip the head of the screw
https://www.kawiforums.com/showpost.p...46&postcount=1
BEWARE the malfunctioning products from www. autolumination .com
furtiva is offline
post #3 of 12 (permalink) Old 06-18-2009, 11:37 PM
heat them first and then use an impact hammer, otherwise you'll strip the head and then you'll need to cut them off.
kkim is offline
post #4 of 12 (permalink) Old 06-19-2009, 12:23 AM
mo1981's Avatar
Sawz-all!
'08 Ebony 250R (a.k.a. "Venom")
Woodcraft clip-ons, Roaring Toyz lowering links, Monster Energy decals, ProGrip grips & tank pad, D&D slip-on, PIAA headlights, Daytona water temp gauge, 15/41 sprocket swap, rear tire hugger, eBay pegs, custom fender chop, needles shimmed, Kleen-Air removed, painted windscreen...
mo1981 is offline
post #5 of 12 (permalink) Old 06-19-2009, 01:34 AM
i heated it up with a heatgun for about 2 minutes.
used a big screwdriver (pretty long too)
and got it out.
just gotta get that loctite heated up and it's pretty easy there on.
i916it is offline
post #6 of 12 (permalink) Old 06-19-2009, 07:21 PM
I had the same issue when removing mine. I used an impact driver and they came off with no problems. I didn't need to heat them up. Granted, they were crazy tight, though.
UNBRE4K4BLE is offline
post #7 of 12 (permalink) Old 06-19-2009, 08:21 PM
Just to clarify, you don't need an impact driver. It does however make it easier to come off.
Good heat will get the job done, with a big enough head on a philips screwdriver.
i916it is offline
post #8 of 12 (permalink) Old 06-22-2009, 02:05 PM
animal900's Avatar
Torches, heat guns, impact hammers? I used my socket set and a little elbow grease. Really not that hard!
animal900 is offline
post #9 of 12 (permalink) Old 06-10-2017, 12:31 PM
7 years later and still usefull
I know this is an older post, but it helped me just now! The screws where nearly all the way stripped, I used a kitchen torch and went at it for at least a minute then used a power drill. It finally came off and I was so relieved.
Dengeki Xena is offline
post #10 of 12 (permalink) Old 06-11-2017, 02:11 AM
94 zx600 rider's Avatar
I took a drill to it then used those retracing bits work great and you can find the screw usually at any big hardware store
94 zx600 rider is offline
