Vex's guidelines and observations in the 250r forum - KawiForums - Kawasaki Motorcycle Forums
post #1 of 50 (permalink) Old 08-12-2009, 01:21 AM Thread Starter
VeX
I ♥ Cute Cats!
VeX's Avatar
Post Vex's guidelines and observations in the 250r forum
Ok, truth be told I don't pay much attention in this section anymore because it has gotten terribly repeatative and IMO not moderated enough.
People don't seem to feel like searching, but blindly creating threads and expecting others to eagerly answer their questions. Then said poster gets flamed and gets a bad feeling towards Kawiforums as a whole. For this reason I'm creating this thread to give simple answers (with links) to threads I see pop up a LOT, general observations, along with a thread on how to search. If I see a thread posted that's been posted 100 times before, I'm going to link to this thread. If you disregard it, I will give you incorrect answers and/or flame you. So here's my blackjack (21) guidelines to make the 250r forum less of "that damn forum" that at times is the plague of Kawiforums.
1.) The tubes hanging underneath the motorcycle are NORMAL:
https://www.kawiforums.com/ninja-250r...off-hoses.html (I merged about a dozen threads all asking that question here).
2.) The gas cap makes noise? That's a common issue, and there's a fix for it.
https://www.kawiforums.com/ninja-250r...-pictures.html
3.) If you did a FE, or changed out any of the bulbs for LED's, and now they won't blink? There's a reason and a couple of fixes for it.
https://www.kawiforums.com/ninja-250r...installed.html (That's one thread talking about it, and how to fix it. There are over a dozen other threads asking that same question and I refer to that generally thread to keep things more centralized on the topic).
4.) You haven't started the bike in a while and now it doesn't run right? Or it runs only with the choke on, and barely at that? You're not the first:
https://www.kawiforums.com/ninja-250r...out-choke.html There are numerous threads about winterizing as well. SEARCH for them and do some reading!
5.) Modifications: Don't ask how to install or modify ANYTHING without first checking this thread. If you don't see a thread pertaining to the item in question, try searching!
https://www.kawiforums.com/ninja-250r...d-diy-faq.html Also notice it's in the sticky at the top of the forum? CHECK out some of the threads up there as a lot of general questions are answered up there!
6.) Are you wondering if a 250 is right for you? Good, this isn't the forum for it. (check the newbie forum, or two wheel discussion forum). This thread is overly congested with people asking that question. It also seems people are embarassed to go into the "newbie" forum and therefore ask those questions in the 250 section instead . There's no shame in asking questions about things you don't understand, and in this case this not the applicable forum.
Newbie Corner : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums <-- Newbie forum --- Two Wheeled Discussion ---> Two Wheeled Discussion : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
7.) What type of gas do you use in a 250? No, it does NOT say 91 octane anywhere on the bike. It says 91 RON which is not the same as 91 RON/MON (the octane measuring system used in the United States). And NO higher octane does NOT = more power... Whatever your pops has told you, or your buddy with the Chevelle swears by, octane does not mean more power .
https://www.kawiforums.com/two-wheele...e-what-ok.html
8.) Every day someone creates a thread asking if they should do *insert modification* to their bike. It's silly and annoying to go onto a forum and blindly ask people to make decisions for you. There are probably 10 threads of people who have installed or done the modification in question and have feedback about it. THAT'S what a forum is about, so do a little legwork! Go ahead and make a thread asking what jet you should use, what sprockets you should use, etc. I am GOING to steer you in the wrong direction on purpose.
9.) What gear should you wear? This isn't the forum for those questions. Gear question is not motorcyle specific so DON'T ask those questions in here. If you have a piece of gear that you wear that only works on a 250, then go right ahead and post it in here .
10.) Have a story about a ride or observation? It doesn't belong in this forum. The two wheeled discussion forum is generally more suitable.
11.) "I want to get more power out of the bike, don't tell me to get a bigger bike!" It's an economy bike... There's a reason why it costs a little over 1/3 of what supersport bikes START at. If you have a lot of money, time, and experience, and knowledge then feel free to drop $4k+ into beefing up your bike to make it a BAMF bike. THEN create a thread about it. I'm serious! It's interesting seeing how people go about custom work and it can also yield creative advice, critiques, etc.... DON'T create a thread though expecting people to give you advice on how to turbocharge, nitrous inject, etc. your 250. If you have to ask those questions, you aren't qualified to be doing those sort of modifications and no there are no power adder "kits" available for the 250 and I doubt there ever will be.
12.) Again the 250 isn't a super sport bike. It doesn't push the envelope in any fashion! Everytime people ask about steering dampers it makes me want to punch a baby. The bike doesn't need it (unless you're racing in a class that requires it). If you are getting head shake, then there is another problem (incorrect tire pressure, balance, head bearings, etc.). Steering dampers aren't magical headshake removers. The same goes for slipper clutches as well
https://www.kawiforums.com/ninja-250r...tabilizer.html
VeX is offline
post #2 of 50 (permalink) Old 08-12-2009, 01:21 AM Thread Starter
VeX
I ♥ Cute Cats!
VeX's Avatar
13.) If you are wondering to buy this years 250, or a used 250, that is NOT very technical and frankly back to the having other people make decisions for you. If you're really persistant about this, ask in the newbie forum. As there are plenty of cases in which a 250 may not be right for you (If you're too big, if you are an experienced rider and want more power, etc.) Lets try to keep the 250 forum more 'technical'.
14.) Did you install or do something and want to tell the world about it? SEARCH to see if there is already a thread about it. Having 10 threads of people talking about their experience with shimming the needles, inquiring about jet kits, fender eliminators, clip-ons, etc. wreaks hell for people trying to find answers to questions. Imagine ONE thread pertaining to a modification or topic along with peoples experiences? Wouldn't that be nice??
15.) The guys with the bigger bikes don't hate you (well not ALL of them). They're flaming you because they've probably been riding for a long time and are very knowledgeable, and you're probably being disrespectful or silly. For you to use a forum incorrectly, trying to relate to them because YOU now own a motorcycle, talk down to them when you don't like their opinions, etc. is at par with me talking war stories with my Grandpa. I CAN'T relate, I WASN'T there to experience what he experienced, etc. I wouldn't dare give him advice or talk down to him.
16.) Should you work on the bike yourself? How the hell does anyone but YOU know that? If you create a thread asking if changing your own oil is easy, you're asking for trouble. There's probably a DIY about the maintenance item in question so you can gauge the difficulty of the job, and if you have further questions, POST them in THAT thread! If you're not mechanically inclined (there is absolutely nothing wrong with that), and the job seems beyond your abilities, take it to a shop! Don't go above and beyond your capabilities, and then find yourself frantically creating a thread at 2am asking where "this bolt" goes, or torque values, etc.
17.) If you are going to do work on your bike, get a service manual! They're not too expensive and will pay themselves off (if you are truly going to do the work yourself) in no time. Torque values are in there along with wiring diagrams, trouble shooting guides, etc. How do you adjust this or that? It's in there! That and I ASSURE you someone has done what you want to do, and created a thread about it.
18.) I'm not kidding. PM me or other knowledgeable members before you create a thread when it's not a crazy complicated question. Myself and many others on the forum are more then happy to answer a simple question! Hell I've created in depth wiring diagrams for people and PM'd them. People who have been around for a while likely know the answer, or where to guide you. Creating a thread to ask, "Hey, what are clip-ons, do I need them?". Is going to get you flack, and only asks a simple question whereas a thread entails a discussion. PM someone knowledgeable and you'll likely get you get a respectful PM back with an answer. It's no problem!
19.) If you're going to ask a question, but are expecting ONE answer and will get upset if someone tells you otherwise... Then you're not asking a question. If you ask about the power benefits of a K&N drop-in airfilter and 2-3 people tell you there are NO horsepower benefits to be had, don't call them ass holes because you would rather them tell you something else. Be courteous and if applicable inquire about dyno proof, flow charts, etc. Have an open mind!
20.) "Is this a good deal on a used 250?". Ask that in another forum (honestly try the newbie forum). It's subjective, and not really a technical at all. There are many people with 650's, 500's, 6r's, 10r's, etc. that started with a 250 and don't frequent this section as well. Asking 250 sale questions in the newbie forum will probably get you an answer from someone who has sold a 250 and knows what they're worth.
21.) If you have an odd predicament and ask a question, BE detailed. "My bike is making a noise"... I assure you there are 100 different noises and dozens of factors to making such a noise. If you point out that it ocured AFTER you tightened the chain, or it goes away when you pull the clutch in, or it happens on a hot day, people can be a lot more helpful.
And MOST importantly:
https://www.kawiforums.com/off-topic-discussion/119829-search-tools-you.html
That's my favorite link to a thread about searching. The forum is a much happier place when everyone gets along. Creating an account to simply make a thread to ask a repeatative question is very inconsiderate and if you stick around long enough you'll see what I mean. (stick around for the spring when the new models come out and a wave of new riders come in asking the same questions over and over and over and over and over and over and over and over and over and over again
Edit: I've also added this: https://www.kawiforums.com/ninja-250r...ing-250-a.html as a general guide to questions/things I've noticed people ask about or consider before buying 250's. If you're one of those people, maybe you should take a gander?
VeX is offline
post #3 of 50 (permalink) Old 08-12-2009, 01:23 AM
whitehendrix's Avatar
jesus vecks....
lol
►Sept09 B.O.T.M. winner◄
Need A "How To"? CLICK ME!!
whitehendrix is offline
post #4 of 50 (permalink) Old 08-12-2009, 01:40 AM
Akai Suisei - 赤い彗星
Kurosaki's Avatar
should I sticky?
Originally Posted by Valentino Rossi
If you don't hang your balls out there and just do it, you'll never know what might have happened.
Kurosaki is offline
post #5 of 50 (permalink) Old 08-12-2009, 01:43 AM Thread Starter
VeX
I ♥ Cute Cats!
VeX's Avatar
Aye. I was thinking so Kuro (I'm not going to point out how silly your question sounds either)
I'm kind of talking about it in the PWT as well.
VeX is offline
post #6 of 50 (permalink) Old 08-12-2009, 01:43 AM
hell yes.
post #7 of 50 (permalink) Old 08-12-2009, 03:36 AM
so i found some tubes hanging under my bike, im thinking about sucking on them to see what comes out. ..
seriously though, some people shouldnt be allowed to have bikes...its not like it is a super complex piece of machinery
PlayCrackTheSky is offline
post #8 of 50 (permalink) Old 08-12-2009, 03:40 AM Thread Starter
VeX
I ♥ Cute Cats!
VeX's Avatar
^^^ I think that's the next "helpful" piece of advice I'm going to give the next time someone makes one of those threads
VeX is offline
post #9 of 50 (permalink) Old 08-12-2009, 05:34 AM
There's one simple thing you are forgetting here. When someone asks an already asked question, it can be of interest to other people reading the threads who might have not otherwise been aware of problem/advice needed. I was reading the forum tonight and read a few common questions.answers that would well have been asked in the past !
virtual120 is offline
post #10 of 50 (permalink) Old 08-12-2009, 11:49 AM Thread Starter
VeX
I ♥ Cute Cats!
VeX's Avatar
That's the point of searching. Say you have something that you are wondering about, and FIND a thread about it, post in that thread. It'll bring it back to the main page and people will see it. By just creating a new thread then you have a whole new discussion on the same problem. Then you'll get threads bumped and have 3 discussions on the same problem ON the front page. Before the 2009's came out there was 3-4 threads about the 2009's on the main page.
It just gets really confusing and it proves difficult to get information on something when you search and find 10 threads on a subject. Then you have to sift through each one, etc. etc. One time with the "blinker not blinking after changing signals" concept I was going to bump every instance in which that question had come up, and answer each one of them the same way. But I'm sure I would've gotten heat from the mods when there were 15 threads on the main page that were IDENTICAL and thus identically answered.
VeX is offline
