Bike won't start after head lapping - KawiForums - Kawasaki Motorcycle Forums
post #1 of 6 (permalink) Old 08-09-2014, 07:32 PM Thread Starter
I lapped the heads and put the everything back together...bike won't start. Only adjustment I made was to to tighten the play in the throttle.
I checked for spark which is present.
I tested the pet cock and it works properly.
I checked the diaphragms and seam to be working properly
Floats appear to be working.
jets are not clogged.
If I blow into the fuel line it sends some gas out of the jets and the bike will start and run for abour 1 second.
Any ideas why my bike won't start?
bandito is offline
post #2 of 6 (permalink) Old 08-10-2014, 11:00 AM
panthercity's Avatar
Have you checked compression? Could the cams be one tooth off?
panthercity is offline
post #3 of 6 (permalink) Old 08-12-2014, 06:45 PM Thread Starter
Anyhow, I did a compression test and got 160 psi and rechecked the timing which is correct. Just got the carbs out and apart. Now to clean and reassemble.
bandito is offline
post #4 of 6 (permalink) Old 08-15-2014, 04:23 PM Thread Starter
I did a full overhaul of the carbs. Bike will start only with choke on and only piston #1 fires. It will start, revs up fast and then dies. If I play with the throttle I can get it to run but only piston #1 fires, idles at 1000 rpm and will not go over 4000 rpm with the throttle part way and dies with the throttle fully open. When I pulled the spark plug for piston #2 it was black and wet with gas. I replaced it with a new one. Same symptoms and after pulling the new park plug it is wet also but not black. Any ideas?
bandito is offline
post #5 of 6 (permalink) Old 08-26-2014, 01:39 AM
FirstXRS's Avatar
Swap coils, see if the problem follows.
Check air.
2008 klx450r SM | Warp 9 | Pilot Power | Acerbis | Vapor | Pro Circuit
2012 zx-6r -- SOLD
2009 klx250sf -- SOLD
2008 zx-6r -- RIP 8/4/11
2001 ex-500 -- SOLD
FirstXRS is offline
post #6 of 6 (permalink) Old 05-31-2015, 03:13 PM
bigbadbass's Avatar
was this bike running just prior to your lapping, or was there a period it was dormant?
bigbadbass is offline
