Sorry for another oil thread. - Page 6 - KawiForums - Kawasaki Motorcycle Forums
 40Likes
post #51 of 56 (permalink) Old 12-13-2015, 10:25 PM Thread Starter
William's Avatar
Sorry this is a bit off topic, but I have a 2012 Toyota Corolla that takes
0W-20 synthetic oil. This is the first vehicle that I've had that takes
synthetic oil. This engine runs way, way smoother than any other
engine I've ever had. If I could find a synthetic that makes my 650R
run as smooth as my Corolla, I'd use it.
185EZ likes this.
William is offline
post #52 of 56 (permalink) Old 12-14-2015, 03:54 AM
GR rider's Avatar
Sitting one meter away from an inline four, or any car engine, with a bulkhead covered with sound proofing material in between is one thing, sitting atop of a parallel twin screwed on a metal frame a few cm away from you quite another.
Anyway, a parallel twin will never be as smooth as an I4 so it would be better for you to simply find an oil, synthetic or not, that makes your 650R run smoother than usual.
And with so much contradicting and officially unsupported information, right or wrong, it would be better to try different oil brands, viscosities and types, always according to factory specification, and decide for yourself which is the best.
GR rider is offline
post #53 of 56 (permalink) Old 12-15-2015, 03:23 AM
chrispage1's Avatar
So, have we actually concluded what the best oil is for the all rounder - obviously lubing the engine, clutch and gear shifts?
185EZ likes this.
chrispage1 is offline
post #54 of 56 (permalink) Old 12-15-2015, 12:46 PM
panthercity's Avatar
Yep, the BEST oil is... the one you're happy with!
panthercity is offline
post #55 of 56 (permalink) Old 12-19-2015, 02:10 PM
Jeff in Kentucky's Avatar
From a recent Bob is the Oil Guy thread:
“At temperatures freezing and above, there will be absolutely no difference in time between 0W, 5W, 10W, and 15W filling the galleries and hitting full oil pressure.
The wear is in the mid warm-up range, not startup, when the initial protection provided by viscosity is lost, and the oil moves into additive control of wear.
The middle range is the range to get through as quickly as you can - don't idle an engine to warm it, use it. [With carbs, the engine will stall if you take off when it is not warm enough, even with the choke still part way on.]
When you do an oil change (with filter), you only change around 85% of the oil because about 15% is stuck in the engine.”
10w-30 vs 5w-40 question | Heavy Duty Engine Oil (HDEO) - Diesel/Gas Pickups/Trucks/Vans | Bob Is The Oil Guy
GR rider likes this.
Jeff in Kentucky is offline
post #56 of 56 (permalink) Old 12-20-2015, 09:00 AM
GR rider's Avatar
When you do an oil change (with filter), you only change around 85% of the oil because about 15% is stuck in the engine”
I agree with both statements, the idling / auto choke revving warm up was deemed unnecessary after extensive testing before and during the early catalytic converter era (it was also causing damage to the catalyst).
I also believe that it is near impossible to get rid of the old oil simply by let it drain which is a good thing as oil should stick in order to protect better. I expected a percentage around 5% though.
GR rider is offline
