Another My Ninja 650 won't start - KawiForums - Kawasaki Motorcycle Forums
 1Likes
  • 1 Post By Mrpockets151
post #1 of 5 (permalink) Old 03-18-2019, 12:45 AM Thread Starter
Mrpockets151's Avatar
I searched for an open thread but didn't get to far. So just yesterday I got this funky sound
https://youtu.be/M268m5xo8fM
I can jump start the bike using jumper cables but as soon as I turn it off it won't start again. I'm getting only 11.4 V with my meter across the battery , when I hit the start switch it drops to 11(this battery was brand new in Sep 2018 when I put it in)
My next plan is to check voltage/resist on the stator . But why does it sound like a relay problem. Anyone ever been through this?
Mrpockets151 is offline
post #2 of 5 (permalink) Old 03-19-2019, 04:13 PM
Dead battery or the stator isn't recharging the battery. The 12v battery should read close to 13v unloaded and still stay above 12v even with a load. Most likely your battery though, even though it's only from 2018.
2009 ER-6N
Yoshi TRC-SS | Puig Screen | Puig Pro Sliders | Spools | PCV | BCM Filter | Aftermarket Mirrors | Evotech Radiator Guard | JPR Short Levers | Tidy Tail by s2r | Progressive Rear Shock | Galfer Brake Lines | Renthal Streetfighter bars | Progressive Front Springs
smknkeyz is offline
post #3 of 5 (permalink) Old 03-21-2019, 08:15 PM
Battery problem most likely, 11v is low after a charge cycle.
If you are hearing a relay click that is a good thing. If you are not hearing a relay click, then I would be worried about the relay and test it out.
Edit:
just listened to your vid and that sounds funny. Almost like a starter issue, but, I would still check the battery. Do you have a local autoparts store that can do a load test? Just bring it down to them.
PeaPod is offline
post #4 of 5 (permalink) Old 03-27-2019, 11:22 PM Thread Starter
With a new battery the bike started right up. I had ordered a battery anyway. I did jump start it so I figured something drained my battery- again.
So I did do measurements pin 1-2, 2-3, 1-3 . I read that somewhere. I got steady 0.7-0.8 Ω . Earlier today I read on a blog that .7 -2 Ω was good. I also read that anything above.3 Ω is bad. I better check with the MOM. Come to think of it I believe I saw it there.
Voltage wise I get 24.7 V with 2 V fluctuation at idle. I think more fluctuation on a certain pin combo.
@ 3000 RPM using the idle adjuster I get 37 with 2 volts flux. I'm just gonna go ahead and pop the cover open. I need an oil change anyway.
I did order a battery tender to use to when if I know I won't ride for more than a few days.
Thanks for the input
Update :: according to ElectroSport article which I found on Bing search , my charge system is fine.
2500 rpm voltage across battery is 13.58 V
5000 rpm voltage across battery is 14.04 V . According to the troubleshooting flow chart everything I fine. See picture.
Oh and I did attach the Tender adapter nicely tucked away for the future. I'll use it if I know my bike will be sitting longer than 4.5 days / especially with low hours on it
ID:	131423   Click image for larger version
ID:	131425   Click image for larger version
ID:	131427   Click image for larger version
GR rider likes this.
post #5 of 5 (permalink) Old 04-01-2019, 03:44 AM
GR rider's Avatar
Good news and no more problems hopefully
GR rider is offline
Similar Threads
Ninja 650 2012 won't start. Greenghost USA 3 09-09-2013 09:17 PM
Ninja 650 Won't Start After Being Hit by Car...Where to Start BuckyD Ninja 650R, ER6 9 07-06-2012 02:24 AM
Bike won't start, and when it does, it won't idle right Jordan777er 2005-2006 ZX-6R 24 10-06-2011 10:52 PM
Won't stay running/won't start... phissure 2007-2008 ZX-6R 10 03-30-2009 10:58 AM
79 kawasaki 650 won't start wwbill62 All Other Models 2 06-17-2005 07:30 PM
