Burning Smell after riding new Ninja 650 - KawiForums - Kawasaki Motorcycle Forums
 1Likes
  • 1 Post By smknkeyz
post #1 of 9 (permalink) Old 04-13-2019, 09:02 PM Thread Starter
Hey!
So I just got a 2017 Ninja 650 with 400 miles. 4th bike but never had one during the break-in period. Every time I stop/park the bike I can smell something burning, possibly oil. I have read some stuff saying it is normal and others saying its the end of the world?
There is no leaks, and I have ridden over 100 miles so it probably isn't spillage from the last oil change as that would have burned away by now.
HELP!!!!
Lord1e is offline
post #2 of 9 (permalink) Old 04-13-2019, 09:16 PM
You're just cooking it off. Make sure you're following the break-in process correctly and the smell will most likely start to dissipate as you add miles.
Lord1e likes this.
2009 ER-6N
Yoshi TRC-SS | Puig Screen | Puig Pro Sliders | Spools | PCV | BCM Filter | Aftermarket Mirrors | Evotech Radiator Guard | JPR Short Levers | Tidy Tail by s2r | Progressive Rear Shock | Galfer Brake Lines | Renthal Streetfighter bars | Progressive Front Springs
smknkeyz is offline
post #3 of 9 (permalink) Old 04-16-2019, 05:38 AM
GR rider's Avatar
Did you ride it in the rain?
My Er smells like fish every time I ride in the rain
Anyway, I think you are going to be fine, there are always funny smells emitting from hot surfaces and different materials and there may be tiny amounts of oil / coolant / other substances that you can't really see.
GR rider is offline
post #4 of 9 (permalink) Old 04-16-2019, 10:28 AM
bigbadbass's Avatar
when shifting/braking keep your sneakers off the header pipes!
'95 Ducati 900SS/SP
'07 Ducati SS800
'98 Honda VFR800 FI
bigbadbass is offline
post #5 of 9 (permalink) Old 04-16-2019, 12:01 PM
Oil and old crap burning off of the headers, should go away soon.
Kevinl7778 is offline
post #6 of 9 (permalink) Old 04-17-2019, 06:17 AM
I have had similar issues with my Ninja as well.
Check for the following:-
1. If you have lubed your chain excessively. This excess lube will get sprayed all over the place and on hot surfaces of the engine during riding and can result in the burning smell. Not a reason for concern.
2. High speeds (> 140 kmph) for sustained period of time will result in some burn of Engine oil. This ,again is not a reason for concern.
3.Check for black soot at the ends of the Exhaust can, after a longish ride. Black soot will indicate engine oil burn in which case you might have to get the engine checked with your mechanic.
Neo18 is offline
post #7 of 9 (permalink) Old 04-18-2019, 04:04 AM
GR rider's Avatar
Not necessarily, 140 / 150 km/h is my usual highway speed and I've ridden 800 mile days with the bike loaded with luggage and zero oil burned. Oil burning was never an issue in general, after years of track days, long trips and casual sport riding.
Also black soot at the ends of the exhaust can is a sign of both complete and incomplete burn that can be attributed to many reasons, some of which are normal.
Having the engine checked with by the mechanic along with the first oil change is always a good idea though, just to be sure
GR rider is offline
post #8 of 9 (permalink) Old 04-24-2019, 07:38 AM
Agree...it should be a non issue in 9 out of 10 cases.
But when you say get the Engine checked during oil change, do you imply checking the engine casing for any oil leaks or does it involve a deeper check like cylinder head lining etc??
Neo18 is offline
post #9 of 9 (permalink) Old 04-24-2019, 11:18 AM
GR rider's Avatar
No, anything involving accessing the upper part of the engine/cylinder head is expensive and unnecessary at this stage. An older, more experienced mechanic will now exactly where to look on the outside. There were cases of oil leakage through the water pump housing but only after quite a lot of miles, but even so I would recommend a check of the surrounding area along with your right shoe for signs of minuscule oil spraying.
I really think that such smells are normal as even stuff like road grime, insects and plain old dirt can cake up in invisible places and give out burning smells when (over)heated
GR rider is offline
Similar Threads
burning clutch smell after hard run patrickzx636 2005-2006 ZX-6R 4 09-20-2012 08:32 AM
First ride burning smell Pauly 2003-2004 ZX-6R 2 03-15-2007 02:38 AM
AKRA burning smell AJWill 2003-2004 ZX-6R 9 02-18-2006 06:31 PM
Burning Smell pmason718 2003-2004 ZX-6R 1 08-03-2005 07:34 PM
