650r kawasaki won't start cold - KawiForums - Kawasaki Motorcycle Forums
post #1 of 2 (permalink) Old 04-14-2019, 05:34 PM Thread Starter
Hi names frank and i have a 650r kawasaki that won't start when it's cold 20 min of cranking it over and it will start if battery don't die first.fuel pump is putting gas out just did the plugs what now help me please
frank69x1 is offline
post #2 of 2 (permalink) Old 04-16-2019, 03:06 PM
Jeffrey Raymer's Avatar
In my experience, cold usually means electrical issues. I had a similar problem with my Aprilia. Turns out the sparkplug boot eroded and wasn't providing enough spark to get it to kick. Once it did start, it ran fine, but I blew up way too many starters. I use lots of dielectric grease on my plug boots which usually helps. You can always use a screwdriver to ground out the boot against the engine or frame to see if you are getting spark. If you aren't, trace the wiring back. If you are getting spark, it's likely fuel not getting all the way to the cylinders for some reason. Also check the start/kill switch to make sure its not intentionally killing the engine. Those are the first things I would do.
Jeffrey Raymer is offline
Similar Threads
650r kawasaki won't start cold frank69x1 New Member Introductions 4 04-21-2019 10:56 AM
02' ZX-6R Won't Start when engine is cold Mark_S ZZR600 & ZX-6R Old School 3 02-03-2016 08:42 PM
won't start when cold rocketman132mph New Member Introductions 1 05-29-2010 08:59 AM
Bike won't start after being out in the cold... OOBE 2003-2004 ZX-6R 8 12-17-2004 01:39 AM
Bike Won't start when cold...help! 97_ZX6R 2003-2004 ZX-6R 4 09-24-2004 02:18 AM
