FI light problem 06 ER-6N - KawiForums - Kawasaki Motorcycle Forums
post #1 of 5 (permalink) Old 04-20-2019, 05:05 AM Thread Starter
Hi, I have problem with FI light doesn't work tachometer light fine it's work i tried external power source and work fine but i tried everything and i can't light up with using ECU. I measured the BR/R cable to the positive pole and read the 12V value but led won't work please help me.
EDİT: I measured the FI lamp output with a positive pole reading 2V. Where did 10V go?
SOLVED. ECU malfunction. But DFI system work fine.
Excuti is offline
post #2 of 5 (permalink) Old 04-20-2019, 07:37 AM
The implication is that the bulb itself is faulty. Replace it ? The way to test is to borrow a gauge from the same year bike and plug it in.
AusEr6guy is offline
post #3 of 5 (permalink) Old 04-20-2019, 09:54 AM Thread Starter
Bulb is fine
Excuti is offline
post #4 of 5 (permalink) Old 04-21-2019, 08:29 AM
bpe
bpe's Avatar
Maybe loose or corroded wiring.
2006 EX500r
bpe is offline
post #5 of 5 (permalink) Old 04-21-2019, 02:39 PM Thread Starter
Solved. ECU problem i think this is transistor error.
Excuti is offline
Similar Threads
Changing gauges on a 2009 ER-6n, Koso vs. newer model ER-6 pod? Mendo New Member Introductions 0 07-23-2014 09:58 PM
05 ER-6N Gearbox problem yaddy Ninja 650R, ER6 5 05-08-2013 04:34 PM
Turn Er-6f to Er-6n Hadi New Member Introductions 0 12-10-2012 06:44 AM
'09 ER-6n Woodcraft frameslider install problem mudhudhudhu Ninja 650R, ER6 6 05-07-2011 10:33 AM
Conversion Kit ER-6f to ER-6n Mt_Matutum Ninja 650R, ER6 9 09-13-2010 06:46 PM
