Exhaust - KawiForums - Kawasaki Motorcycle Forums
post #1 of 6 (permalink) Old 06-15-2019, 11:44 AM Thread Starter
Exhaust
I've a 2009 er6f /ex650 ninja and I was looking to change the full exhaust on it would the header pipes from a 2012 model fit as I've seen a nice stainless one but it's for the later year cheers
theukbeast is offline
post #2 of 6 (permalink) Old 06-16-2019, 12:09 AM
There’s a guy who retrofitted old pipes to a newer engine and he had to make some kind of collars. It was on a versys forum somewhere.
The older pipes are sought after because you can have a slip on. The newer ones are one piece.(this is what i understand and could be wrong as well) Ill see if i can find the post
Its a guy called JD rocks and he used a 2012 engine with an older exhaust I cant find the relevant post im sorry
AusEr6guy is offline
post #3 of 6 (permalink) Old 06-19-2019, 06:40 AM
Found this over on riderforums user fencingdud101 posted about an arrow exhaust system hed bought...
It weights in at 9.5 pounds, so it shaves just about 9 pounds off from the stock exhaust, and should make a good bit more horesepower after tuning, of course. We have a little fab work to do to make it fit the 2014 bike since it was made for the 05-11 models (Mostly regarding enlarging the header ends from 35mm OD to 41mm), so that will occupy my time for the next little bit, on top of making a custom seat frame and welding in some steering stops. Luckily we have half a year to do all this stuff!
So if you want to fit an 05-11 exhaust on a 12- bike you need to open up the headers OR use 35mm OD 1.5mm thick tube to make up some collars as i alluded to earlier.
Hope this helps ?
post #4 of 6 (permalink) Old 06-20-2019, 05:15 AM
GR rider's Avatar
Arrows headers also work with newer models too, in combination with any model specific slip-on.
GR rider is offline
post #5 of 6 (permalink) Old 06-20-2019, 06:41 AM
I have it wrong way around. The newer model headers wont fit the older bike. I have seem some models that come with collars that are removable.
post #6 of 6 (permalink) Old 06-20-2019, 06:50 AM
GR rider's Avatar
Creative as always!
GR rider is offline
