Frame Crash Bungs\Sliders Recommendations ? - KawiForums - Kawasaki Motorcycle Forums
 5Likes
post #1 of 13 (permalink) Old 08-14-2019, 08:26 AM Thread Starter
Piston_Broke's Avatar
So after my little Err accident a couple of weeks ago
I've been looking into getting some Frame\Crash Sliders, I know that R&G are a fairly popular brand here in the UK but does anyone have any others they'd recommend ?
Piston_Broke is offline
post #2 of 13 (permalink) Old 08-15-2019, 03:59 AM
mdr1970's Avatar
I wouldn't recommend anything other than R&G, Evotech, or Kwak OEM - This is one thing you do not want to try and save money on, since its sole purpose is to help you save money if you are unlucky enough to actually need it!
Piston_Broke likes this.
Personality helps, but ATTITUDE is everything!
2014 Z1000SX (ABS Tourer) Made in JAPAN, Perfected in the UK
mdr1970 is offline
post #3 of 13 (permalink) Old 08-16-2019, 11:04 PM
Whatever brand you get, you probably want to avoid the no cut frame sliders. They can pivot out of the way and crack things anyways. The cut versions are much more resistant to that as they typically don't have any pivot points and the only real risk is that they might catch at speed. But, so would no cut ones.
If you've got plastic that's been cracked, I've had good experience with plastifix and a dremel. The kit isn't that expensive and the repairs appear to be pretty strong.
pfranks is offline
post #4 of 13 (permalink) Old 08-19-2019, 11:51 AM Thread Starter
Originally Posted by pfranks View Post
Whatever brand you get, you probably want to avoid the no cut frame sliders. They can pivot out of the way and crack things anyway. The cut versions are much more resistant to that as they typically don't have any pivot points and the only real risk is that they might catch at speed. But, so would no cut ones.
Thanks i didn't even realise there were 2 types of fitment i just assumed they all fitted bolt on etc. I think i'm leaning towards the R&G at the moment which i believe is a cut frame slider or at lease it looks more like it.
Thankfully it was a stationary lay down as i put my foot in a pot hole and couldn't hold her up so damage was minimal except a mighty bruise on the back of my leg where i tore my hamstring trying to hold her up
https://www.kawiforums.com/ninja-650...-car-park.html
post #5 of 13 (permalink) Old 08-19-2019, 05:27 PM
You don't want to know what will happen to your bike when crash bung meets immovable object during a medium speed slide
Machinist is offline
post #6 of 13 (permalink) Old 08-21-2019, 12:40 PM Thread Starter
To be fair if i'm in a medium speed slide i'm guessing what the crash bungs are doing will be fairly low down on my list of worry\priority's
mdr1970 likes this.
post #7 of 13 (permalink) Old 08-21-2019, 06:11 PM
So you opened a new topic about how bad you feel about scratching your paint after a static fall while hurting your leg at the same time but now you suddenly don't give a damn about totalling your bike after a minor slide.
Good luck is all I can say...
post #8 of 13 (permalink) Old 08-22-2019, 04:58 AM
mdr1970's Avatar
No need for this comment what so ever - The OP is only stating that they would be more concerned about self preservation, rather than mechanical in the event of a more serious 'off'
As previously mentioned regards crash bobbins. In my experience and I have had experience, both on and off track, they defintely help in the unfortunate event of a drop and if they dont dig in they REALLY help during a slide! Check out my pics from an off I had earlier this year after a pheasant flew into my face round a right hander I'm an even bigger fan now of my R&G bobbins, since my fairing, mirrors and even my camera remain untouched - HATE to think what the repair bill would have been without them!!!!!
But for sure, if your bike is gonna connect with curbs, trees or any other more solid objects they aint gonna do much, but money can fix anything that happens to your ride; the same cannot be said for your body!!!
ID:	131819   Click image for larger version
ID:	131821   Click image for larger version
ID:	131823   Click image for larger version
ID:	131825   Click image for larger version
mdr1970 is offline
post #9 of 13 (permalink) Old 08-23-2019, 12:56 PM Thread Starter
As MDR Stated i'd be more concerned with Myself Primarily and then the bike after
Just Looking at the R&G Sliders and one side is direct Fit i think (Right) on the Bike and The Left hand side has a No Cut Bracket ?
https://www.rg-racing.com/browsebike...)/2016/CP0314/
So Now i'm really confused ?
post #10 of 13 (permalink) Old 08-30-2019, 10:23 AM
I have Puig Pro sliders. I haven't "tested" them out yet, but have always felt they'll do the job when called upon. Weren't too bad install-wise either.
2009 ER-6N
Yoshi TRC-SS | Puig Screen | Puig Pro Sliders | Spools | PCV | BCM Filter | Evotech Radiator Guard | JPR Short Levers | Progressive Rear Shock | Galfer Brake Lines | Renthal Streetfighter bars | Progressive Front Springs | BRP 180 Rear Tire Conversion
smknkeyz is offline
