2016 z1000 Kill switch install on 2010 er6 - KawiForums - Kawasaki Motorcycle Forums
 2Likes
  • 1 Post By AusEr6guy
post #1 of 5 (permalink) Old 09-16-2019, 02:55 AM Thread Starter
Found a cheap one on eBay that looked smaller. In my case it came off a 2016 z1000
They fit on a treat but the wiring doesnít match. If plugged in the bike will crank regardless of switch position or button press. Ask me how i know.....The plug is the same.
I repinned the plug and Iím back on the road 22g lighter lol.
To repin
On the switch plug thereís two tabs on the side and these retain a sort of collar within the plug.
Press these in and the collar should come out
Thereís a rubber o ring below that, remove that too
Then each wire has a small plastic tab that holds it in place.
Use a scribe to push down and remove the wire then, re pin as per my pics
GR rider likes this.
AusEr6guy is offline
post #2 of 5 (permalink) Old 09-16-2019, 03:09 AM Thread Starter
Here’s some pics
ID:	131861   Click image for larger version
ID:	131863   Click image for larger version
ID:	131865   Click image for larger version
ID:	131867   Click image for larger version
post #3 of 5 (permalink) Old 09-16-2019, 03:36 AM Thread Starter
Last pic
post #4 of 5 (permalink) Old 09-16-2019, 04:57 AM
GR rider's Avatar
Nice job - info
GR rider is offline
post #5 of 5 (permalink) Old 09-28-2019, 06:00 AM Thread Starter
I should mention that the reason I needed a new switch was that I’ve moved to a z1 brake master cylinder and Zx6r throttle housing was required because the cables were in the way. So to change the throttle cables, I had to change the switch ...
found out I had a quick throttle tube on my bike in the process also; winning !
For those interested, theres R6 throttle tubes on eBay that fit for under 20 bucks
Apparently “2006 Yamaha r6 throttle tube and grip has a 40mm throttle cam. The 05 tube has a 38mm cam”
