How-To: Prepare for a track day - Page 4 - KawiForums - Kawasaki Motorcycle Forums
post #31 of 40 (permalink) Old 02-05-2010, 09:08 AM
Micron05rr's Avatar
Thanks for the info runfromme, will come in handy for my first ever trackday at Jennings on the 21st. Rep sent!
2005 ZX6RR - 1/4 mile - [email protected] videohttp://www.youtube.com/watch?v=w_KQhDSCvQA
Micron Serpent Full System - BMC Race Filter - Kawasaki Race ECU - PC3- Dynojet Quickshifter -Thin Head Gasket - Denso Iridium Plugs - Chevron 93 Pump Gas -Redline 30wt Full Synthetic - Geared -1, +4 Renthal Ultralight - Short Wheelbase -
www.mpsracing.com
Micron05rr is offline
post #32 of 40 (permalink) Old 05-07-2010, 11:33 AM
straytowel's Avatar
Originally Posted by runfromme View Post
-Air Pressure Gauge - You will run lower air pressure on the track than you would on the street, even if you're using street tires. A good starting point for most tires is 32 front/30 rear. Check with the tire manufacturer or your local shop for their recommended setting. Set the pressure when the tires are cold.
One thing that I recommend doing is setting the pressures slightly higher before you get to the track (35-37 or so). This way when you have the bike there at the track, all you have to do is let air out to get them to proper cold pressures. It sucks having to run around to try and find a compressor/air pump (I found this out last weekend when I didn't factor in humidity the day before and it dropped a few psi the next morning).
straytowel is offline
post #33 of 40 (permalink) Old 05-07-2010, 05:17 PM
^ bring a bicycle pump. they're light, relatively portable and unless your tire is completely flat, quick and easy to use in a pinch if you're just inflating a few psi
Question....does anyone just take their bike to the track for a track day?
1) I don't have a truck or anything to transport
2) It's only about an hour away
3) I could probably fit most of the essentials in a backpack and tape lights, etc there?
Do people do this or would I be laughed off the track?
i've seen it done many times and it's possible, however it's best to find a ride there and split fuel costs with the other person.
you'll be very tired after your first trackday
former AFM #282
stingray is offline
post #34 of 40 (permalink) Old 08-17-2010, 11:34 AM
chuckbear's Avatar
Bump for a great thread. Gave me a lot to think about for my upcoming track weekend!
chuckbear is offline
post #35 of 40 (permalink) Old 08-25-2010, 08:20 AM
TTD
Site Sponsor
One thing I'll add is to put a hose clamp on your oil filter. It costs $2 and can save everyone a lot of headaches.
It adds ZERO time to an oil change and is re-usable!
On many bikes, the hose clamp doesn't even need to be wired. If the space is tight, you can just rotate the nub of the hose clamp against the motor...and tighten. Worst case, you can safety wire it.
The biggest problem with oil filters is that 99% of people don't use a torque wrench...and everyone tells them to not overtighten them... so they end up vibrating loose just a bit... and spilling oil everywhere.
Anyway, at TonysTrackDays we require them - but in reality everyone should spend the $2 and do it.
Here is a link to a page with a "clamped" filter. Personally, when I wire a clamp I do it to the nub area (the part where the bolt is), but you can really wire it anywhere as long as the wire prevents the clamp from turning. (in this photo, it looks like the wire is around the whole clamp...it should be in one of the holes)
http://www.tonystrackdays.com/catego...reparation.htm
TTD is offline
post #36 of 40 (permalink) Old 10-05-2011, 01:30 PM
Strat - the Asian edition
bubbleboys's Avatar
This may seem stupid and not apply for some of you but this is something to keep in mind for those of us in areas where it gets cold.
This was a tip that I got from a coach this past weekend.
When it gets cold, make sure your coolant won't freeze. If you're still doing track around this time, you know that it may be "warm" during the day but it may easily get below freezing at night.
The coach told me the story of a guy who trailered his bike to the track arriving at the track around opening. He unloaded the bike, started it up, and ended up cracking a head gasket or something like that. Turns out his coolant had froze or whatnot.
May seem like a stupid thing but it's one of those things you don't think about.
Learning that has definitely scrapped my plans to move to water wetter or whatnot.
Originally Posted by katina View Post
Well it's better than banging every shmuck who does so much as smile at me. I'm not that desperate.
Yet.
"oh herro your honorbrel honor. I no speed on your highray."
bubbleboys is offline
post #37 of 40 (permalink) Old 01-09-2012, 05:17 PM
stlcbr's Avatar
Great write-up! It always seems like you forget th most important thing and don't realize it untill you need it.
Bike spares aren't the only spares that might come in handy. I always bring my other helmet, boots, and gloves. You never know what might happen. A get off, or even something as simple as dropping your helmet and your visor mount breaking could be a BIG pain in the ass. I like the piece of mind knowing there won't be much to keep me off the track once I get there
http://www.youtube.com/user/STLCBR
2005 Honda CBR 600rr - Track Bike - R.I.P.
2009 Kawasaki zx6r - New Track Whore
stlcbr is offline
post #38 of 40 (permalink) Old 09-16-2013, 01:30 AM
I am really passionate for racing cars. These cars entice me. Itís my dream to have a car like this. I want to drive on a race track with racing car.
Speedway 660
savannah is offline
post #39 of 40 (permalink) Old 07-11-2014, 10:27 PM
livin4hockey's Avatar
Rep'd again because this just helped me get through my first track day, what a blast!!
2005 BMW Alpine White 636 SOLD
livin4hockey is offline
post #40 of 40 (permalink) Old 07-12-2014, 10:03 PM
JRxGRUBZx's Avatar
Track days are awesome
JRxGRUBZx is offline
