Does anyone know if some parts are interchangeable like the front fairings? Or even the lower fairing? Hard to track down parts for the ZX9R!!
Thanks
norm, did you try researching the parts diagrams on kawasaki.com??
i'd imagine that you wouldn't be able to do a direct swap. if anything you would have to swap the mounting brackets as well. and i believe the air intakes are different and woud need to be swapped if it could be done.
zx6r fairings are very different, it wont work... however you can upgrade everything to 00-03 zx9r style fairings. but it it one or the other. if you go with the newer style you'd need the upper itself, headlight, fairing bracket, gauges, ram air, and windscreen. as far as the mids and lower fairings 98-03 are all the same.
