So I've been trying to get this bike to run right. Running off a small auxiliary fuel tank for testing. I've cleaned the carbs twice now, had them off about 4 times messing with the floats. I set them at 17mm (spec) the first time I cleaned the carbs. Put new needles and idle screws in. Jets looked pretty new, stock size. Cleaned the emulsion tubes. Right now the bike starts right up, I was riding it around for a few minutes going through the gears and I thought my problem was solved, no dying good throttle response ect. This time I set them to 16mm to fill the bowls up more, correct? The bike will idle forever no problem. But I went to ride it a second time after it got hot, it bogged a little bit in the mid range and I thought fuck. Its doing it again. Put around a little more I loose throttle response, and it boggs out and dies. After it does this it will only start with full throttle. Let it sit a few minutes, and it starts up revs up fine whatever. Its gotta be the carbs... it really sounds like the floats are off, but I used a micrometer to set them... I might try to put the tank on, with my new petcock, and see what that does, I doubt it though. I'm pretty stumped, so I'm looking for some advice and if anyone else has had this problem. I adjusted the floats with them just touching the spring in the needle, not depressing it. I've done them before on my fj1100, with 4 carbs. How does this piece of junk with 2 carbs not work correctly? I'm tired of tinkering with it, I just want it to work right so I can sell the damn thing and make some money. Battery at 12.9 fresh off charger, when running it was at like 13.3 something close to that.
How many miles are on the bike? Typically with these engines, it's a combination of things that causes them to run poorly. I'm wondering if you need to adjust your valves as well.
I went through a similar process with my EX250. It had been neglected over the years, and while it did run, it was a pain to get it running and warmed up. The choke was especially finicky.
I went through the long process of cleaning and rebuilding the carbs, and while the engine ran a little better (proper air/fuel ratio finally), it was still very tough to get going. I went in and adjusted the valves, and was shocked as to how out of spec they were. 26,000 miles and they had never been adjusted. The bike runs like a dream now - easy cold starts and plenty of mid-range power.
